B747 down in South America?
I have gotten this second hand,but I am told that Joe Kennedy is in a Tampa hospital,is conscious and demanding diet Coke. He seems to be doing amazingly well,but I still haven't heard the true extent of his injuries or how long the rehab process might be. Sounds like the old Joe I know is fighting hard...I am praying that his recovery continues...
who??????
I think these guys did a awesome job. I was just saying the possibility of sabatoge is extremely high. Shouldn't 74 fly on two engines at 9000-10000 thousand feet even at gross?
Cruising and Climbing are two different things. Bogotá is already at 8329 MSL add the altimeter and temp correction, well you get the point.
For those of you who didn't know, Joe Kennedy was the flight engineer on the Kalitta 747 thatcrashed in Bogota..He was one of the guys with several severe injuries and was given only a 30% chance of surving.
It has been a very long day and I can't believe I made that mistake...Sorry...I have known Joe Kendall since the early 70's and he is indeed in the Tampa hospital..
Hopefully Tampa General......if he is there....Dr Angel (his real name) is taking care of him and his going to have everything on his side. He has pretty good odds with him.
I am still amazed that anyone lived, losing two engines in a critical phase of flight at what was probably max gross with temp and baro corrections shaving the margins even closer not to mention an 800 foot level off to bump the weights even more (these are assumptions because almost everyone operates this way) and all this assuming the weights are correct. The crew deserves support from their fellow pilots. I always felt safer flying out of Bagrum than Bogota and still feel that way.
I hope for a speedy recovery for all.
Actually, three engines were lost. #4 failed just as the gear was comming up. Shortly thereafter,#1 rolled back. At that time firewall-thrust was applied and #2 failed. The pink page profile was flown in and out of stick shaker and after 3 minutes and change of airborne time, the capt made an off airport landing in a field between two small cities. Having flown into Bogota for a number of years, he knew the fields location and was able to miss the populated areas thereby possibly preventing hundreds of fatalities on the ground.
If those facts are true then they did one helluva job! Condolences to the family of those killed, but it could have been much, much worse.
I do think the FAA is going to be looking hard at Kalitta's engine maintenance program after two engine related crashes.
Which runway did they depart from ? I can't imagine making any of those fields using 18L with a left turnout, maybe from 36L and even then it is pretty amazing.
Can any of us say that we would have had the balls and the brains to to sustain the loss of three engines and fly it to a field in the middle of the night, just to not kill a lot of innocent people on the ground.
What kind of bullshi_ maintenance existed that the same plane could lose three engines ?
I am filled with anger and rage that any crew would ever be placed in that position. At the same time I am in awe and have such great respect for the heroic actions of the crew that night.
May God bless them and care for them and their families. They were brave and they are heroes.
Your concern and kind comments are appreciated, but stuff a sock in your "anger and rage" for a while. Let the investigation play out before making these accusations against maintenance.
BTW the runways are 13/31.
There is no 800' level off in BOG. I think level off and first power reduction occurs around 13,000 ft when your clear of terrain.
And this is the official NTSB conclusion? Call Connie and tell him it was a three engine failure, because nobody told him three! If your K4, you should not be posting BS!
Why?
It should?
Quite an assumption. But then, what do you know?
1. Regardless of circumstance, it sounds like the crew did a superb job of making the best of a very very bad situation.
2. They were still slow when the engines started failing. At best you might be able to control your descent rate.
3. Let's wait for the report to point fingers. You can bet they're looking at maintenance, as well as fuel quality, etc.
Sounds like bad fuel or a huge flocks of birds. Who knows. I hope the crew is doing better, especially JK. Best of luck guys.
Pprune says Kalitta had another plane with engine failure from the same airport. Any truth to that?
You're reviewing old news.
You tend to make up your own "truth" anyway...usually with prejudice...so why don't you drum up something to spew again, and simply say it?
Handbags at 50 paces?
You guys never miss an opportunity to argue. :D
(Hi Avbug! How ya been? The IFR Monkey is almost out of office. We'll have to come up with something for Obama-lama-ding dong soon. :D )
I get it. You Kalitta guys are strong here, special your venomus BS. Somehow, if your Master, Connie keeps conning the law, not all of you can do the same. Some day the Law will catch up with you. And if not the Law, life has lately showed you some signs. You should learn out of it.
Master? Again, you post nothing but assumptions.
You also make strong accusations regarding what you know not.
If you have specific knowledge, instead of wild, unfounded speculation and lies, then by all means post it.
Your credibility meter is presently at zero. You surely can't do any worse.
avbug,
Just ignore countbat! All it is, is a rabble rouser. Stop feeding the poor thing and maybe it will retire to the bedroom and get the keyboard sticky there, and render its outlet unusable. The world would be relieved!
avbug,
Amen! Let it go die in a corner.
