Question Avionics Circuit Breaker Switch Fail
I ordered spare push pull breakers from CubCrafters. Price was reasonable. The 50A breaker is $315!!! So that's a no for me for the spares kit.
I realize I probably missed the ignition breakers on the front of the seat which I believe are 40A's? Doubt I'll get anymore, have what I have for now.
I was wrong, the ignition breakers forward of the seat are 5A.
Opened my package from CubCrafters and the packaging for breakers is all aircraft spruce so just buy direct from them.
Many years ago a friend of mine blasted off out of KBFI in a rented Mooney 201 into the overcast. After getting radar contact with departure and a getting on course the entire radio stack died…in actual IFR conditions-the master CB Switch had tripped.
After extracting a bunch of seat cushion from his nether regions and a few unsuccessful reset attempts all of the radios were turned off and the avionics master successfully reset with no load. In a trial and error method radios were turned back on and it was determined that one nav/com with no GS receiver would not trip the master-anything more and Still, no xpnder, no DME, no ADF (it was a while back!), no second nav/com and no precision approach capability!
After re-establishing contact with SEA and declaring my friend got vectored around and pointed back to BFI which fortunately wasn’t that bad-about a thousand and 2 or so and he got back in okay on a localizer approach.
In an effort to learn from the experience of others, when I set up an IFR panel back in the day I had two Master Avionics switches installed in parallel. In order to ensure continued redundancy I would use one on odd numbered days and the other on even number days.
There is little enough redundancy in a single engined airplane and to expose yourself to a single point failure of that kind is an easy fix with almost no cost in weight.
I understand that most Garmin LRUs can accept multiple power sources, and I further understand that the IBBS can be connected to more than one device.
While some Garmin LRU have 2 independent power inputs I doubt it is true that "most" Garmin LRU have two independent power inputs. GPS 175 (and family) do not, GTX 345R does not, GAD 29 does not, GMC 305 does not, GSA 28 servos do not, G5 does not (but does have independent battery backup option).
In the CC Exec Glass aircraft IBBS powers GDU 465, GSU 25C (feeds GMU 22), and GEA 24. A good IBBS battery will power these for 2 hours or more. Adding loads would reduce that but, if load does not have independent power inputs, additional power switching would be required.
The standard Exec Glass Avionics switch breaker is 10 A and I suspect it is barely adequate. Very surprised that CC did not increase the rating for the IFR fit.
Does the Avionics switch need to be a breaker type? Each avionics LRU has its own CB.
If you are concerned about loss of everything on the Avionics bus then consider two independent Avionics switches. How would you decide which LRU to put on Avionics-1 and which on Avionics-2. You have likely have only one audio panel, one transponder, and one IFR GPS.
I don't have the audio panel in my IFR capable FX-3. I could rig an alternate power source for the GTR 200 but it's not high on the list of priorities.
CC G3X Schematic shows the Avionics switch breaker as 10 A.
CC schematic -103 CC11-160 POWER DISTRIBUTION AND START CIRCUIT shows a 20 A Avionics switch breaker. This schematic is listed as applicable to the FX-3.
The equivalent schematic in the maintenance manual template is of too low a resolution for the CB rating to be read clearly but I think it is 20 A.
Very good information, thank you. This is exactly the reason why I'm not going put up with this being a single point of failure.
Everything that is on the Avionics bus will go away if the Avionics switch fails, or if the master contactor or its wiring fails, or if the Master switch fails. The Avionics bus will likely be shed if the alternator fails so that battery capacity is retained to keep the engine running.
Eliminating single point failure of the Avionics bus powered equipment requires more thought than just considering the Avionics switch.
If Avionics power fails, or if all Master power fails, I still have GDU PFD and ND and a G5 as backup. What I'll likely miss most is COM and secondly the Autopilot.
If/when I install my GTR 20 remote COM I may consider putting my GTR 200 on a different power source or add switching to manually select an alternate power source.
I have also been considering manual RS-232 bus switching so the G5 and GMC can give me AP after the GDU fails.
Failure of the GDU 465 may be far more debilitating than loss of the Avionics bus.
@Cactus Charlie thank you for the opportunity to bounce this around with you! Would appreciate your thoughts on the following:
1) GDU 465 failure would indeed be majorly problematic. However, with my panel, the GDU 465 is powered by the IBBS if the Master fails. I suppose there's a risk that the GDU itself fails leaving me with the G5 only, but not sure there's much I can do about that.
2) How is the G3X's internal GPS (not IFR certified) powered? If Master loses power, will the internal GPS work via the GDU 465 being powered through IBBS?
3) I spoke to an avionics tech yesterday and he also concluded that a 10A avionics CB switch is marginally inadequate. He also observed that all avionics units are protected with their own dedicated circuit breakers. He suggested moving up to 20A CB avionics switch, or even converting to a standard switch. What's your view between those two options?
4) What would be involved in installing an additional independent avionics switch in parallel with the current switch? My current panel does not have a blank, unused space for an additional switch. Can an additional switch basically be added wherever I can find space?
5) If a second Avionics switch was installed, in your opinion would this be sufficient redundancy to then not worry about further redundancy such as additional IBBS connections?
6) As I think about what minimum IFR equipment I would really not want to lose in IMC, it's the GDU 465, the GNC 355 (which gives me one radio) and the GMA 245R audio panel. This would mean losing the second radio and the transponder - which wouldn't be great but doable. The GDU 465 is already connected to the IBBS. You mentioned above that the GNC 355 and GTX 345R cannot accept an IBBS backup power source. Can the GTR 20 and the GMA 245R accept IBBS back up power? If answer is no, is there any other creative solution for powering LRUs that were not built to accept IBBS backup power if the avionics bus is deenergized?
