spudskier
- Dec 29, 2004
again, as mentioned and the way I understand it, a visual approach is a straigh-in approach... if you're coming in from any other direction than from straigh on (which the controllers usually vector you for anyway) then make a beeline towards a place that will within one turn, put you on final... anotherwords the shortest route to final approach if not already on the final leg, no 45 to a downwind, go to the airport and land (of course adivse CTAF that you're "x" direction from the airport inbound for a visual runway "x") but this is not standard pattern entry as you would if you were VFR... as I understand it
