Assignment of PIC / SIC
hiropilot
Hey! Watch This!
I searched the old threads to see if this had ever been discussed before. No able to find anything so I would like to inquire here.
The debate is - does a pilot have to be checked as SIC to be assigned that position if he/she is qualified as a PIC on that aircraft? My position is that even though the pilot was trained and checked as PIC, he or she has to also be trained/checked for SIC assignment to be made. Other side of debate is that since the PIC is a higher position, no checking required for SIC to make assisgnment as SIC.
Part 135 is very clear on what is required for PIC but isn't very specific on the SIC issue.
We have a pilot that completed training same as PIC but will only be checked as SIC. I don't have a position on this part of the argument since I haven't come across that scenario before.
The answer I am looking for is legal interpretation on the intent of the regs for assignment of SIC is pilot hasn't been checked for SIC, only PIC.
Thanks in advance for all input.
I'll take a quick stab at this, in a nutshell:
135.245 lists SIC requirements (minimal, basically appropriate pilot certificates). A qualified PIC would meet this.
135.293 checkride every 12 months for pilots, i.e. both PIC and SIC. A current PIC would meet this one by default.
135.329 training program requirements for pilots
So, the specifics really come down to whatever is in your company's approved training manual as far as what's required for ground subjects, flight maneuvers, req'd training time, etc., for SIC's. More than likely, PIC training would check off all the boxes (and more) required for SIC, but you'd need to check your training manual to make sure.
Exactly my position except that at a previous employer, we got dinged by POI for assigning pilot (that was qualified as PIC) as SIC but he had not been "checked" in the SIC position. Would you agree that if the pilot was checked for PIC and then did a takeoff and landing from right seat then should be okay if issigned either position?
Thanks!
Each visit to FSI, the instructor makes a note that SIC proficiency demonstrated. We don't fly charters, but in the event we did, this statement, along with meeting the requirements of our training manual, would allow either PIC to be assigned SIC duties. Not a big deal.
You have to demonstrate a takeoff and landing from the right seat to be able to act as SIC. Every recurrent I have had to do this.
That statement assumes the aircraft is SIC/PIC seat-dependent. OR the FOM specifies PIC/SIC seats. That's pretty much a 121 thing...not so much 135.
Pic/sic
It depends what you put on your Training/Checking Authorization for your Training Provider. If you put check both, they will put a note SIC demonstrated in the remarks section of the 8410. A PIC check requires more manuvers in addition to the ones required for an SIC. So essentially by default, they may be "duty assigned" as a PIC/SIC if noted on the 8410.
Okay, all good info. Thanks for the replies. I think it gives me enough ammo to continue to debate my side of it.
this is the correct answer
if your in a jet on a 135 that requires 2 pilots its going to be assumed that their are PIC duties and SIC Duties both seperate. One doesnt cover the other. In order for a PIC to sit as SIC he or she has to demonstrate those duties in training (thats why all these sim training places have that). 121 of course covers this more thourough but a sharp FAA guy in 135 would hold the company to it. Most dont.
