Asiana 777 crashed on landing at SFO
Uh oh, Jon Scott (single engine private pilot) from Fox News now solving what caused the crash, everyone can go home now, case solved.
Top of fuselage burned because..........oxygen canisters burning???????
Looks like there was a United whale waiting for T/O on 28L when they came in... Wondering if they saw happen.. or at least thought they were low....
Major news outlets now also reporting 2 dead. Injured estimates vary, highest I've heard is 70. MSNBC reporting that 10 patients at SF General Hospital are critical, some patients were intubated & put on ventilator (breathing machine). Likely cause would be smoke or toxic fume inhalation during egress from the aircraft
Someone yelled GO AROUND at the 22:15 mark of the 1800-1830Z tape followed by the controller's voice in a completely different tone of voice
Here's an accurate eye witness account. This should clear things up...
“The tail was too low. Instead of coming in flat it was coming in at, I would say, maybe a 45-degree angle, with the tail far too low,” she said. “It really went through quite a few acrobatics on the runway.”
If you click this link and select SFO final app you can hear Asiana 214 before the control tower. Choose the time starting at 18z. Unfornunatly ATC transmissions are not heard. But the Asiana pilot seems relaxed. After hearing the other control tower transmission where somebody yelled "go around" and suddenly a new more serious sounding ATC took over. I believe the plane crash at that moment and the pilot of Asiana 214 was transmitting from the ground afterwards ( although I don't understand him). The controller states all emergency vehicles are on their way. I not sure this was a emergency aircraft prior to the crash but I could be wrong.
http://www.liveatc.net/archive.php?m=ksfo_twr
I've been in there recently. They've been re-working both of those thresholds. See the black marks that have painted over the old threshold on both runways?
When I landed there recently, 28L was closed (still working on it) and 28R was open....GS OTS. We had to do a LOC approach at an international airport. Do-able for sure, but a little strange for the airport size.
I'm wondering two things....did they have the GS for 28L re-certified yet after changing the threshold? Same question about the PAPI.
These things can happen when the FAA and/or the Airport authority decide on some major change to the airport. The pilots should have still had the airmen skills to land.....but still.
I saw a picture of the evacuation, evidently taken by a Samsung exec who was a passenger. At the time the fire looked as if it was only on the right side of the aircraft, the fueslage was largely intact, and the slides were deployed.
And there were two female passengers walking away from the wreckage......WITH THEIR CARRY ON LUGGAGE.
Where is the face palm icon?
Sad to see two killed and dozens injured but it was a pretty good job by the cabin crew of evacuation before the fire really got going and CFR was on scene quickly.
Meanwhile, I will choose to ignore the TV know-nothings and wait for the NTSB to weigh in.
The all knowing source of news channel 4 in LA.. just reported that 61 people are missing?? Huh... God these news people really need to stick to high speed chases...
The SFO spokesman was really quick to end the presser once the question was asked "if the glideslope was working". All he said was the skies were clear and pilots were shooting visual approaches.
From what I hear in the tape, it sounds like the accident is called in the background before the go-around call that is blocked by the Cessna. The go-around call sounds like the RJ behind the Asiana 214.
Ah, the dreaded hand-flown visual approach in a blistering 7 knot quartering headwind in daylight conditions with no ceiling....could have gotten any of us...there but for the grace of god....
Unless it was a repeat of Speedbird at Heathrow when ice blocked the fuel to the engines. Kind of a bummer to push up the throttles and get bupkus.
Don't be too quick to judge.
There but for the grace of god indeed. Real thoughtful of you. Don't think we know all the details yet either.
Yes, it could have been any of us. Depending upon the circumstances, this could turn out to be a success story where the pilots saved hundreds of lives.
Later they will report the sharks got em.
Can't help but think of the similarities here with the BA 777 at LHR. Landed short also, but after a longer flight and across the pole I believe. May have been different engines, but what about the fuel system?
Sad to think of the loss of life and injuries.
Two incidents with very similar outcomes would suggest that a very urgent and expedited investigation of the 777 is of utmost importance. Since the data should be readily available, hopefully this can be accomplished fairly quickly.
Sent from my Galaxy Nexus using Tapatalk 2
