ASA jet makes emergency Landing with gear up!
jetracer5
http://www.myfoxatlanta.com/dpp/news/Delta_ASA_Jet_Makes_Emergency_Landing_061109
ATLANTA (MyFOX ATLANTA) - Hartsfield-Jackson International Airport officials confirmed Thursday that an ASA commuter jet was forced to make some sort of emergency landing.
Delta officials said the plane may have experienced possible tire problems.
Fire and rescue crews responded to the scene.
Delta officials confirmed that everyone made it off the plane safely.
Operations at the airport were still running smoothly Thursday, and there were no reports of delays as a result of the incident.
Good job to the crew!
Glad everybody is OK.
Wonder if they knew they had a problem with the gear ahead of time, or a "surprise" gotcha on touchdown?
If the rumors I heard are correct; indeed the pilots did a good job. Incidents like this really bring home the point of the seriousness of the job and the talent the profession maintains, despite the lackluster wages, earning potential and job security. Perhaps a loyalty to this vocation akin to that of a teacher; Kudos to all involved.
They landed on 27R in ATL which is the longest runway we have and usually only used for departures. So im guessing they knew they had a problem
By the flight track looks as though they knew about it, Lt MLG problem, before hand and did an excellent job of dealing w/ it. Looks also like it was one the airframes from OH.
Anybody have a flight number or aircraft number?
someone had a really bad night, we taxied past it and the ADG was out... looks like more than gear.
Kudos to the crew on a job well done. On the plus side, you've now got a great story for interviewers and grandchildren alike.
I was sitting between 27L and 27R waiting to leave when they were on their 1st approach to ATL on 27L. Told tower they needed to go around for a gear disagree. I took off before he came in and didn't hear about the outcome until a couple hours ago. Job well done!
ASA does get credit for completing the flight, A14 not too sure about. They did indeed know that it was a problem before touchdown. A call was sent out by company to "go team" members after the first attempt at landing, this was while the aircraft was still circling or being vectored to approach.
Job well done. The big question is what would Sully have done?
It was an ASA tail number 200... not a former OH bird. Looks like the left main might have partially extended but not fully, or collapsed on touchdown.
When we taxiied by the people eater had already come out and taken all the pax and such away but the trucks were still out there. They were about 50 feet off to the left of 27R with all the hatches open.
Great job to the crew, and I hope they are sleeping well tonight after a few cold ones.
Which Tail Number?
What tail number was it? I don't suppose it's "Slider," the special Atlanta, landfill, anthill plane that slid in 6 or 7 years ago?
Sully would have peed his pants and gone screaming into the night!
With no landing gear the airplane probably just thought it was in the air, and when they turned off the engines and APU after landing, tadaa!
I was working yesterday and our A/C was visited by MTC and I was told by line MTC the A/C involved was in the hanger 2 days prior for an uplock either being replaced or adjusted the mechanic wasn't sure... just passing on the info. Great job to the crew.
Then that would be the same cause as the left gear up landing in PHL of a AWAC CRJ 200. Aparently that bracket can not be seen visually while putting the pins in. If the mechanics don't swing the gear quite a few times they may not realise a problems with instalation until it's airborne. Then it's too late.
It's so early in the investigation... I'm sure they will find out the cause just found it odd that it took 2 days for the problem to happen.
