PBRstreetgang
Registered Abuser
- Mar 4, 2002
Sure,Um, you do know something about CRJ systems right? You do single engine taxi on #2 right?
#2 is on the right
Genius
PBR
Yeah,
And when #2 quits, that leaves how many powering the pumps? ADG will power what at 10 kts?
Thought so!
I say positive rate, gear up, you say gear up, nothing more, nothing less.
PBR
Now shut up and do as you are told!
Yeah,
Thought so!
PBR
Nothing in project APU says anything about taxiing with #2 and no APU, but don't we do that anyway when the APU is deferred? Taxi on #2, then cross-bleed later? Maybe I'm confused on that...
#1-sure, if there is nothing in the way, like another airplane,ramper,tug, ect. How many times can you use the nosewheel steering before 0psi?See #2 below.The systems training must be pretty bad over there, PBR.
Single engine taxi (number 2), no APU
#2 engine fails...one of three things occurs:
1. airplane rolls to a stop undamaged
2. pilot uses hydraulic pressure stored in the brake accumulators to safely stop the airplane
3. pilot declares an emergency as the airplane rolls into the terminal because he/she didn't know the brakes would still work well normally for several applications after the engine failure
Next time you pull into the gate and shut your engines/apu down and hydraulic pumps off, check the pressure readings on the brake system. They don't immediately go to zero.
PBRstreetgang;1574308 ... #3- nothing you would know about said:I'm not sure why you would have First Officers slide their seat back and fill out paperwork when approaching your parking spot...seems a little unsafe.
You're correct. I can't yet claim to be among the tens of thousands of pilots who have at some point in their career achieved 25 years of service in this godforsaken industry without scratching an airplane. At present time, I can only claim to be among the tens of thousands of pilots who have achieved ten years of service in this godforsaken industry without scratching an airplane...and two of those years were spent flying in an environment far more demanding than the scheduled part 121 world.
To be quite honest, I don't expect I'll see 25 years in this industry...unless there are significant changes for the better, which seem unlikely. The company I work for already can't afford to pay me what I earn in other non aviation related endeavors.
I agree that posting while drinking leaves something to be desired. That's why I'm taking it easy on you until you regain full use of your mental faculties.
I don't remember writing that I was a First Officer, but if it helps you believe your penis is bigger than mine, I'll play along.
You may have the final word. I've more important things to do.
