ASA -700 Loses Engine After TO in MEM
Long Time Gone
Never Did The Atkins
http://www.11alive.com/news/article_news.aspx?storyid=114922
According to "witnesses" and emergency types, flames were "shooting out of the back of the engine". Flowboard shows it being airborne for 1 hr and 9 minutes before returning to MEM.
Sounds like Ship 720 is becoming the new "Christine". I think it's the same one that had the right thrust lever lock at idle in a descent below 10K inbound to ATL about a month ago.
And? Isn't that why we practice those?
Maybe more important news would be the takeoff AD that had to be issued so that regional jet pilots could learn how to rotate a swept wing jet.
One hour in the air on an engine failure?? I dont fly an rj but that seems a little strange....did they not want to do an overweight landing?? Were they on the phone with maintenance trying to relight?
Anyone care to explain? I'm sure there is a good reason but unless you fly an RJ I wouldn't know.
They returned after 10 minutes but the rampers TDY from Atlanta didn't park them for another hour.
How did the thrust lever get stuck? It's not connected to anything, did something break in the throttle quadrant and wedge itself in the mechanism?
Agreed. These new guys consistently come within 10 of the barber pole. I've tried to explain to a few of them after saying "don't do that again... slow down..", but I think it's a futile effort.
WELL GOOD JOB TO ALL THE CREW!!!!
is hillarius the terminology use by pasangers and the news: " The pilot seemed to hesitate a little bit then he gave it all she got and we went up "
cap: ok theres V1 should I...not maybe I should no no no...
...talk to me Emilia talk to me.:erm:
Probably the thrust reverser or fuel cutoff interlock malfunctioned.
After "giggling" the thrust lever, it freed up. Upon landing, both TRs deployed, but the right TR lever would not advance above Reverse Idle. Mx stated that it was probably a micro switch malfunction.
And I've tried explaining to old guys the difference between Vmo/Mmo and maximum diving speed...which is about .12 mach higher. Ten knots below barber pole is an accpetable airspeed that will not compromise flight safety. Maybe these "new guys" know a little bit every once in a while...unless you are referencing flap limits...in that case, disregard.
FishNFly must be referring to the "Low Speed Cue" (Red/Black Checkerboard).
sounds like they experienced transient compressor stalls on take off based on the memphis tv story. Or was this thread about 200hr FO's? I forget.
Maybe, it was misreported--never happened before?
This thread lacks the serious Deets that I require!
How do you see flames shoot out the back of engine where your on a CRJ? That guys got awesome peripheral vision. Or maybe he was catching a ride in the aft equipment bay.
I hope it's connected to something!
It's FADEC so there's not a whole lot of mechanical stuff going on there, but as Oakum said there is a fuel shutoff latch (for lack of a better term) and a thrust reverser mechanism. I suppose one of these could have been the culprit.
no story here - fod damage to the compressor. stalled a few times and the crew shut it down. nicely done and well handled. engine will be changed per mtc.
