Air France 447 Found
So, based on the speculative NOVA theory. They either:
Could have flown pitch and power (attitude flying) but didn't.
Tried to fly pitch and power but couldn't.
Air France or Airbus?
I'm anxious to see what the real story turns out to be.
What I was asking was that, if the pitot system iced over, as is the hypothesis in the NOVA episode, and thus the ADCs would be getting false data, and the flight control and engine computers would be making decisions based on that false data, would the pilots still be able to set known pitch and power settings?
Would the pilots be able to select a throttle position that would give a known power setting? Would the stick inputs actually be turned into flight control movements?
In other words, to what extent can actual manual inputs (over-riding what the computers 'want' them to do) be made to an Airbus' flight control system and engine power system?
The Nova episode has a crew deal with the same emergency (as known from fault data sent). With the numerous faults given to them (including lack of airspeed and air data faults), the are still able to maintain control through a pitch/power setting combination. What's implied in the episode is that with everything gone, they should have been able to maintain control (although they cannot be certain until the data recorders are recovered). What they used to come to the hypothesis is that there has been quite a few instances where crews in the airbus have been slow to recognize reduced thrust settings (not sure how this system is different than on a Boeing).
Pitch and power day VMC is one thing, but pitch and power at night, in a rockin' thunderstorm when you may not have been expecting it is another. None of us was there, thankfully, and I'm not trying to guess what happened. All I do know from years of crossing the ITCZ at night at relatively low altitudes, (we cross the main routes from SA to Europe on our run, so we are always held down, 30-32k) is that I absolutely dread the moonless nights, even more so when there are clouds maybe hiding those embedded storms and buildups. We do know that is was a nasty night that night, but I have hit the tops of things that had gone unseen and which didn't show up on radar on relatively quiet nights. Those sure get your attention.
And just because two aircraft passed through minutes earlier doesn't mean it was safe for the last one, as Delta found out the hard way in DFW back when windshear was beginning to be recognized and understood (1986+/-?).
One more thing that got me thinking after watching the Nova episode: What if the turbulence is so severe that you cannot clearly read your instruments? In this case to maintain pitch and power? I had never thought that it could be impossible to clearly read my instruments but happened to me twice due to mountain waves. Add darkness, iced pitot tubes, super-cooled water droplets, radar shadows... ugh!
Have never flown a Bus, do they have an angle of attack indicator? If so, is that information displayed on a PFD/HUD? Does it display information independant of the Air data computer?
I wonder if that could have been valuable info for the pilots when they lost airspeed indications?
Have read a book on the Edmund Fitzgerald, which sank on the great lakes back in the 70's, in only 530 feet of water. Apperently after 10+ years in the very cold depths of Lake Superior, they found bodies still in good shape, all thing's considered.
I think they did a great job on the analysis on Nova. I am glad they found the wreckage on the bottom of the Ocean finally and hopefully can piece this all together with the newer clues.
Back in the late 80's Midway Airlines went with new MD-80's and taught full up systems. They wanted everyone to use all the automation all the time. After a year when guys started coming back for there recurrent training we found out most guys lost a good portion of there proficiency flying the airplane manually. Training at the time changed there ideas and instructed the guys to go back and do more hands on flying to stay sharp.
I have never flown an air bus but with all the automation and he fact the throttles don't move at all (Big Mistake IMO on Air Bus's part) I can see where guys can get complacent with there flying skills. Couple that with middle of the night flying where your tired and not thinking the clearest and bad weather where that back line of thunderstorms was blocked out by the echo's on the first cell, lightning in your face and hardly being able to see the instruments because of turbulence was as good of an explanation as you can get for loss of control of the airplane.
Unfortunately we all learn from either the mechanical malfunctions in airplane disasters or the Pilots that make crucial mistakes at the wrong time. My generation of pilots is retiring now and we were more the seat of pants type of flying. The newer generation is the more technical type of Pilot with full automation. I hope the younger generation learns from these mistakes and continues to keep there hands on flying skills honed so if/when this happens again you will be equipped to have a better outcome than Air France did.
I think it has to do with "Autothrust" in the Airbus vs. "Autothrottle" in a Boeing.
In the Airbus the Thrust levers stay in a detent and don't move regardless of the thrust setting. In an Autothrottle aircraft the thrust levers move with reference to the thrust commanded. So with a hand resting on the thrust lever you can get a feel for what thrust is set and what the computer is doing.
Along the lines of Basic Attitude flying, Aeroperu 603 was another accident where they had no pitot static instruments, with the clacker going off. Flew around in the shaker with the gpws going off. Over the ocean on a dark night. Unfortunately didn't end well either. They couldn't tell what was real or not with the conflicting warnings.
Yawn ... Ever heard of the weather phenomenon called the ITCZ? Ever talked to pilots who cross it on a regular basis? Besides, LH and IB had both crossed the approximate location without any problems just a few minutes prior.
http://www.bea.aero/docspa/2009/f-cp090601e1.en/pdf/f-cp090601e1.en.pdf
page 67, crews in the vicinity all reported significant thunderstorm activity. They made large deviations off course, experienced St Elmo's Fire, moderate turbulence, and communication difficulty with ATC.
Yet another reason to avoid flying an Airbus product.
Call me crazy, but I like to know exactly what the **** the aircraft is doing when my hands are on the controls.
Yea, I just recently started flying an aircraft with autothrottles about 2 months ago. I already find my self trusting them more than I would like.
Question for Airbus people, can you guys over ride the thrust (bump it up, if you get a bit slow) without disengaging the autothrust? My only experience is JS'ing on them and I never saw the pilots do this, seems like we over ride them quite a bit in the Embraer on approaches, not sure if our at system is just weak though.
We do not override them in the same fashion as on the Embraer. Any movement above the climb position (MCT position in a SE scenario) we own. Below to top of idle is owned by the autothrust when armed. You can bump up the thrust to a point but if you touch TOGA your going around. There is a whole other function that comes into play when it comes to tweaking the thrust on approach. (GS Mini) but we could start a whole new thread with that one. Long and the short of it is the autothrust does a pretty good job. Even when it's gusty. Unfortunately sometimes it lacks finesse and gives everybody in the back the impression we are racking the thrust levers back and forth just for fun. That is usually GS Mini doing its thing. If all the back and forth starts to bother me then I just match & mash and poof no more autothrust. Sorry for a over simplified yet lengthy explanation but unfortunately that is kind of the story with the Airbus. Simple yet complicated.
The autothrust system works great in climb, cruise and descent. A few people, at UAL anyway, fly with the autothottles engaged during the approach. It does ok. Most of us turn them off and hand fly the approach. Does a great job then.
I may be wrong but this sounds like someone that has never flown the bus. You do know exactly what is going on.
PS everyone knows what **** means. Creative swearing?? :)
Heh heh... That's the ONLY way of swearing that's allowed on the board. That's why when you use a real swear word, the board edits it and puts ***** in its place. ;)
But you're correct, I've never flown the bus, and as the previous poster mentioned, I'd probably be one of those people who would likely kick the autothrust off in any other situation than a constant-state thrust application such as climb, idle descent, and cruise or anytime it was chasing the speed badly enough to do that throttle up-throttle down "chasing" thing they seem to do when you're in the back.
Don't like not seeing what it's doing at ALL times, that's for sure.
If you want to see what it is doing all you have to do is look at the engine instruments. It shows what it is currently doing, what it is commanding it to do and what the engine will be doing several seconds from now...
I once rode jumpseat on a large carrier out of Denver. One of the PMC's on an old 737-300 started dancing around causing the autothrottles for that engine to chase the proper setting.
Long story short the Captain called SAM (what is that?) and after a few minutes came back, turned to the FO and said "leave the autothrottles engaged until we have established V-target on final, then you can disconnect them."
Pure genius. I'm sure the passengers hardly noticed the 10 degree left and right bank for over an hour!
This thread makes me think he was an Airbus guy who recently made the transition.
Gup
No, thank you.
I'm busy enough when the weather's crappy, there's an abnormal or emergency situation, and/or there's some other distraction to not want to include the engine indications every second in my scan. I like that when my hands are on the throttles I know EXACTLY what power setting is being commanded in real time.
I'm sure FiFi is just fine to fly in day-to-day ops, but I prefer Boeing products. Maybe I'm just too much of an old "stick and rudder" guy coming up from Cubs and Pitts towing banners and flying old King Airs, Lears, Falcons, and 727's that were mostly older than I was at the time, but it's simply a personal preference based on jumpseating and what I hear from pilots... like this... that just make me shake my head and wonder whether the engineers designing the plane ever bothered to consult a pilot from time to time.
In many ways I agree with the Southwest mentality of automation levels. Much easier to be connected to what the airplane is doing if your hands are on the controls and either feeling them move or moving them yourself manually. Just my .02 cents.
Lear, I hope every guy senior to me who flies the Boeing has your same mentality. "Ew..it's different and I don't like it." "Real pilots don't fly by ones and zeros." "If it's not Boeing, I'm not going." Go with it. The junior Airbus pilots appreciate your concern and encourage you to remain on your current fleet. Some part of me wonders if the old radial pilots said the same thing about the B-707 and DC-8 when they came out. "Just a fad", they probably said. "Not a real pilot's airplane".
I think today's student pilots are getting a HUGE disservice by learning to fly in glass cockpit trainer airplanes. You want to learn to fly? Solo in a tail-dragger and then move forward from there. If you can't do an NDB approach in a non-glass cockpit aircraft I don't think you have any business having an Instrument Ticket in your wallet. But, those days are fading. Truth be told, I regret never getting the chance to fly 727 or doing a max-power take-off in a lightly loaded 757. With that said, they'll have to pry my cold, dead hands off the Airbus stick. It's like playing chess to a Boeing's checkers. You have to think ahead of what the computer is GOING to do if you want everything to turn out looking effortless...and every so often, shut everything off and hand fly it. It takes a while to really "get it", but it's actually quite a kick in the ass...
EDIT **Just heard this from my Delta mechanic neighbor who is trying like hell to wrap his head around the old NW Airbus aircraft. You know why a monkey can't replace an Airbus pilots? Because it can't get driver's licenses to get itself to the airport.
t.
I hope you arent telling me that my time trying finesse 4 R-3350s last year was all for nothing? :)
Quite the opposite. I consider the Airbus to be a wonderful "office". However, I also spent Friday at the CONFEDERATE Air Force hanger. B-17, B-25, A-26, that isn't work...that is HEAVEN. Radial engines will ALWAYS be where it's at. And you, sir, are one lucky SOB.
