Aerobatic
psysicx
Can anybody recommend any aerobatic aircraft kits perferebly a tailwheel.Also can any of these be used for cross countries?Thanks
Define aerobatic. Do you just want to do the occasional loop, roll and spin? Or do you want an aircraft suitable for all the standard inside/outside manuevers and lomecvaks? There's quite a few that match the first catagory, not many that suit the latter that make decent X-country machines.
For recreational aerobatics, look at the RV series. RV-7 if you want side by side, RV-8 if you want tandem seating. The RV-9 and RV-10 are NOT aerobatic. Great cross country airplanes, too.
I agree with Fraccapt. Look no further than the RV series. While something more "unique" may seem attractive to some, I think as a first time builder the wealth of data, experience, help and information available for the RV series outweighs any "style" points. Not that the RVs don't look good, I've seen some outstanding examples, but people's tastes do differ.
I saw on RV-8 do the Sportsman routine, he didn't score that well, but he was able to all the maneuvers.
Well, if you're running an RV-8 against a bunch of Edge 540's, Extra 300's, and Pitts....it's not going to do well. For basic, recreational aerobatics, the RV series is more than enough.
The_Russian said:
If you want a real aerobatic kit plane, look no futher than the Steen Skybolt or the Pitts S-4!
Did you mean S-1?? Never seen an S-4.
Any pitts will be fairly uncomfortable for x-country. But you cant beat the performance for the price. You can easily compete up to advanced in a $28,000 S-1S.
I was building an RV-8 at one time, it is very easy for the first time builder and there is tons of support available. Riveting is not as hard as you would think and there are comanies out there that make a tool kit specifically for the RV so that you buy one kit and have everything you need (clecos, riveter gun, rivet squeezer, dimpling tools, everything!). Look on the Vans website for more info (www.vansaircraft.com).
Also, the parts come pre-cut so all you do is cleco, open the holes to final size and rivet, with some deburring here and there. The surface finish is great - far better than a 172...
BTW - the posted link above for ebay is a RANS not a VANS.
True, but the sportsman routinely is normally geared to be able to be done in lower end aircraft. It was a couple of years back that I saw it, but I think it was because he zeroed a maneuver, was the reason that killed his score.
Neither have I. I know of the S-1, S-2, and Pitts 12....but never herad of an S-3. The S-1 and 12 are kits, S-2 is factory built.
My apologies,
Steen has since changed the name of the S-4 to the S14. It is a modified S-1 with a MV-14 radial rated at 400HP. It is a join venture between Curtiss Pitts and Steen Aero Lab.
A few weeks ago, someone posted about purchasing a Yak 50. He said it was very affordable, good X-C aircraft, and a great aerobatic platform. Do a search, I believe it may have been in the military forum. Plus, you can fit them with the M-14PF engine. Hold on tight!!! That thing would climb like a home sick angel. Not a kit though.
psysicx said:
Thanks for the help.Is it that hard to build?
I've helped a freind build a RV-7, It wasn't exactly easy, but it wasn't terribly difficult either.
Anybody with a good basic mechaincial ability can do it.
I plan on building one whenever I finally have a garage to do it in.
The thing I like about the RVs is that there is likely sombody building or flying not to far away. This gives you sombody you can pester for advice and help.
There is quite a support network among RV builders....just go to Yahoogroups and search for Van's. I am a member of many of the groups, and we all help each other....plus, as you said, there are many builders in my local area that we all help each other. Local EAA chapters are also a great resource for such info.
