AA587 and the airbus a300 rudder failure
That's rudder pedal movement, not force. Just because the NTSB labels it "pilot input" doesn't make it so. Lots of things can cause a rudder pedal to move.
I may be a bit biased, but for some reason I want to pull for the dead pilots. They don't get to share their side of the story. (Incidently, I feel the same about Egypt Air, another aircraft that had automation problems before its last flight).
By the way, there's a huge discussion on this at PPRune.org. Go to Rumour and News or some of the technical/engineering forums.
The FDR did record rudder pedal inputs, but its sample rate was only about 2hz, meaning that rapid back-and-forth movements were not recorded accurately by the FDR (it only recorded what it saw every 1/2 second).
Are you saying that this rudder was pushed back and forth, full motion in less than 1/2 of a second, maybe you should apply for a job with airbus
Go to the library and find the 11/25/02 issue of AW&ST. Engineering analysis of the rudder reversal phenomena of that accident.
thanks for all the answers. any body would have some documentation about the system itself?
thanks
College boy, a previous poster mentioned AW&ST, that means Aviation Week and Space Technology. Any college worth it's engineering salt will have back issues, of which I'm sure there are articles that go into detail that the vertical stabilizer of the A300 is a composite structure. I would guess carbon-graphite layers built up into a sandwich. I have no idea how it was fastened to the airframe, which is metal. It was a lug which the vertical stabilizer was fastened to was what failed. There were also NTSB hearings which Airbus engineers explained the structure and rudder system, google much?
Interesting that a previous post stated the lug which failed was the one which was repaired in the field. Did not know that . . . .
Also they determined that the rudder endured multiple, at least three I think, full deflections from one side to the other, before the stabilizer let go. Metal bends and cracks when it yields, but composites snap and break apart.
Enjoy your class, study hard, maybe you won't have to be a pilot and will be home most nights!
At some point in your report, you should insert the following:
From the day they start flying, pilots are taught that operating below the "maneuvering speed" for an aircraft means that the pilot can deflect the flight controls to their limits without breaking the airframe. This mishap demonstrates that ain't always so.
Va is the speed at which the aircraft will stall before the positive load limit factor is exceeded. The negative limit load factor, as well as lateral limits can still be exceeded at Va. Many of us were taught as you describe, but it was incorrect.
so who do you blame for the A310 (Air Transat Flt 961?) that lost a rudder at altitude during cruise a couple years ago?
JetBlue/LUV/Airtran or ALPA or management or commuter pilots or low ticket prices or Congress or old pilots.
