wmuflyguy
flunky
- Feb 3, 2004
A Mode C transponder uses static pressure to transmit a pressure altitude signal to the ground based equipment. The ground computer then corrects the data for the local altimeter setting and displays the data for the controller. Essentially, the transponder and altimeters were using the same erroneous pressure data.
I didn't think about that...good point.
