747 Splits in Two on T/O
No TR....we all make mistakes...hope this isn't true....
Again with the assumption.
What information do you have that indicates this was, or was not a mistake...or where has that been suggested?
The latest report suggests that the reversers were not deployed. The reason has not been shared presently, and accordingly any effort to suggest this is a mistake (were they unable, or did they have a valid reason not to deploy reversers?) is a wild assumption.
Wait for the facts.
Wait for the facts.
I thought the preliminary was fact. I guess you have "speculated" that this is not fact? The report does not "suggest" that the TR's were not deployed either. Not that the TR's are going to make a rats arse difference in the stopping though. I'm sure Kallitta does not factor in TR's into their runway analysis anyway.
It's sound as though the abort was initiated after V1. I hope for my Kalitta brothers this is not true. I'll wait and see what the final report says. But still this is a FORUM Avbug. So anyone can say whatever they think happened. And then I expect you will rebut whatever is said.
Well then; you thought wrong, didn't you?
The NTSB preliminary statement listed the wrong runway. The FAA's initial statement listed the wrong airport and wrong city. Go figure. While neither is handling the investigation, each is involved. Any preliminary report should be taken as a grain of salt. That's why it's a preliminary report. Even the NTSB, which is among the foremost authorities in mishap investigation, provides the disclaimer that the information may be inaccurate or incomplete.
Perhaps you didn't think at all.
Sounds? Sounds suspiciously as though you may be hazarding a guess, there. You've drifted from what you thought were facts, to guessing.
Nope. The poster to which I responded suggested a failure on the part of the crew to deploy the thrust reversers. that the thrust reversers are not deployed is clearly evident. That the crew failed in some way to deploy them, however is not.
Did the reversers fail? Did something occur which prevented their deployment? Did a condition exist which dictated best judgement not deploy them? We don't know. I speculated on nothing. My point is consistant as always; don't speculate. You dont' know; don't start rumor. To suggest the crew failed to deploy the reversers is guesswork, with no factual evidence to back it up. Perhaps they elected not to, perhaps they were unable. Until the facts emerge, it is always best not to guess.
This is a part 25 performance issue, and yes, the reversers make a difference. That is, of course, irrelevant to the outcome here, as the reversers weren't used. The rejected takeoff procedure for the airplane, and for the operator, includes idle thrust, maximum braking, ground spoilers deployed, and yes, maximum reverse.
Yes, they certainly can, can't they? Even if it's guesswork, entirely unsubstantiated, lacking for fact, guesswork, or a work of their imagination. Even if it contributes nothing but rumor. Even if they're an idiot for doing so. You betcha.
The humorous irony, of course, is that you're most offended by sticking to the truth and the facts. You'd rather celebrate ignorance and rumor. That's your privilege, of course...however unprofessional and foolish it may be.
Thanks for the rebuttal Avbug. I'm not going to argue with you about this. But I do believe that TR's are not used in runway analysis for computing Max takeoff gross weight for a particular runway, and then of course V1.
Can anyone from Kallitta verify that TR's are not used in computing your runway analysis?
I know at the two 74 outfits I worked at it was not.
That's correct. TR's are a bonus, and not accounted in the rejected takeoff performance...same reason that RTO demonstrations for certification are performed with brakes only. Additionally, with maximum braking, any TR benifit is additive to the total deceleration, as opposed to a normal landing where minimum or medium autobrake settings modulate and the deceleration isn't increased by reverse thrust.
Can't speak to the 747 Thrust reverser issue as I am not qualified on that airplane. However,I do know that thrust reversers are not factored in for a rejected take-off or used in computing landing distances on our ATI DC-8s (they do have a tremendous amount of stopping power on the 71,72 and 73 series ) I used to fly the C-130 and L-382 and they used 2 in reverse and 2 in ground idle for computations. My point being that unless you happen to be a qualified Kalitta 747 crewmember,any speculation as to how or why reversers were used or not used is just that..Speculation...
Like the previous poster I can't speak for the 747. But I thought per CFR certification, reverse is not allowed to be factored in for landing/RTO data.
From Flight International magazine's web-site.
Overrun Kalitta 747 suffered power loss but no engine damage
By David Kaminski-Morrow
Investigators in Brussels have found no evidence of engine damage on the Kalitta Air Boeing 747-200 freighter destroyed in a take-off overrun on 25 May, but confirm that one engine suffered a loss of power at a critical speed threshold.
The Belgian inquiry has also determined that the correct aircraft parameters, runway selection and weather data were uploaded to the 747’s computer before departure, and that use of runway 20 would not have posed any problems.
Two pilots, two engineers and a passenger accompanying diplomatic cargo escaped after the jet broke into three sections during the overrun. There was no prior structural failure; the break-up was caused by impact forces as the jet went over a 4m (13ft) drop.
“At this stage there is no reason to make urgent recommendations,” says the Service Public Federal Mobilite et Transports, which is heading the probe.
Analysis of the flight recorders, it says, shows the initial part of the take-off roll was normal, with constant acceleration until one of the Pratt & Whitney JT9D engines suffered a “momentary” loss of power.
This power loss, which was accompanied by a “detonation”, occurred as the aircraft reached the V1 speed – the threshold beyond which a crew normally must commit to becoming airborne, because the aircraft cannot be stopped safely on the runway.
The crew heard the noise and air traffic controllers witnessed flames from the right side of the aircraft.
Two seconds later the engine thrust was reduced to idle and the aircraft decelerated, but failed to stop before the runway end. Thrust reversers were not deployed, although a rejected take-off calculation does not take reverser use into account.
All four engines were operating as the 747 overran and, upon inspection, showed no sign of catastrophic failure. The engine cowlings were not punctured.
Following the indications of a possible problem with one of the right-hand engines, these were subjected to an initial endoscopic inspection of the high-pressure turbine and compressor.
“This inspection, although incomplete, failed to reveal any internal damage,” say the investigators. The fan-blades and low-pressure turbine remained in place and were similarly undamaged.
Specialists are to carry out a more thorough teardown and examination of the engine components.
None of the cargo pallets had shifted significantly during the accident, but the investigators are to check the loading distribution as part of the inquiry. The jet had stopped over in Brussels as part of a service between New York JFK and Bahrain.
avbug, were you crew? You must have been the way you're arguing.
Only one thing should have stopped that AC from going airborne after V1, and that is multiple engine failure which is about as likely as getting struck by lightning.
No matter what, after V1 the ship goes into the air. Successfully aborts after V1 are rare and the crew is lucky that the fuel tanks were not compromised (thanks Boeing) or they would be TOAST.
I know Avbug will have my a$$ for this, but it's sounds like a compressor stall. Those JT9D engines are well known for it.
No. However, that would be irrelevant.
Perhaps it was, perhaps not. It really doesn't matter, presently. If it was a compressor stall, then it would be an incidental contributing factor at best. If it was not a compressor stall, then it's far too early to factor in the cause, as nothing but ancillary observations have been made. The tower reported flame. That could be a compressor stall, or it could be any number of other things, too. Why did what, what happened with what, and the decisions that were made have not been revealed.
I have no desire to have your "a$$." You may keep it.
Avbug..it would be a mistake because TR' deployment is part of the abort procedure.....can't think of many reasons you wouldn't use them if you decided to discontinue the T/O.
Failure to use the thrust reverse would only be a mistake if the crew either willingly refused to follow procedure without good reason, or failed to remember to do so.
Not deploying the thrust reversers intentionally due to mitigating circumstances or a mechanical failure would not be a mistake on the part of the crew.
We don't know why the crew did not deploy the reversers, or for that matter if they attempted to do so and were unable, or if the reversers simply didn't deploy. That information is not presently available. Therefore, to say the crew made a mistake is premature, and in lieu of evidence to the contrary, in error.
(And now the simplified version)
Assuming that they were working correctly, yes... It would be a mistake.
Watch out with that generalization. Let's say you're at V1 with the yoke or stick in your lap and the nosewheel doesn't leave the runway. The airplane's pretty much made the decision for you that you're not going to fly that day. And there are plenty of scenarios where that could happen, from gross mis-loading to flight control malfunction to configuration error. Actually, they all have. I'm sure Fine Air for instance would have rejected the takeoff in MIA a few years back if they had known that the aircraft was unflyable. Would you rather go off the end at 40 kts or crash a mile away?
And a reject after V1 doesn't mean you're going off the end either, unless you're at or near runway performance limits. Kalitta very likely was that day, but in general, we don't always operate at runway limits. Of course you'd have some 'splainin' to do if you reject after V1, but there's no guarantee that you're going to fly just because you've passed it.
I know Connie got from the insurance a new engine to replace the one lost in Michigan Lake. But also I heard he secretly sent a scuba divers team to recover the lost engine. What IF that engine was on the BRU's 747 bird?
Dude . . . like when are you going to lighten up on Connie? You are once again mal-informed and show how your distaste for Kalitta can make you appear to be more ignorant than you may actually be.
The engine was recovered, although it wasn't in the clandestine manner in which you describe.
The recovery was made by a marine salvage company and was the result of a joint effort, and shared expense, between Kalitta Air and the NTSB. Both parties were present for the search and recovery.
The engine was disassembled, and, you may find this as odd, but the fault was attributed to factors beyond Kalitta's control. The report is available.
Umm.. no
We train for an engine out at V1. After V1 with an engine out or on fire, we continue. There are many things things that can happen to an airplane at or past V1 that would be catastrophic if continued. For instance, #2 comes apart and takes out #1 with it. You are not going to make it to Vr before the end of the runway. Hell, I bet you would lose directional control and begin to drift off of the runway. Vmcg at V1 is only guaranteed with one outboard engine out. If you are losing directional control after V1 you have to reject. If you hork it into the air you will vmc the thing into the ground.
OK! You are really starting to piss me off with your misinformation.
The engine was recovered by a salvage crew because the NTSB wanted to see it. I have personally seen the engine, and trust me when I say it, or any part of it, will never fly again.
This is probably just bait (which I took), but seriously, just go back into your cave.
Count Bat is nothing but a Flame Bait hero.
Posts nothing constructive and it's all garbage.
With a bit of research before posting you would know that they were two different models of PW JT-9 engines. Aircraft 704 had JT-9Q's the engine in the lake was either an A or a J.
Back to you cave CB and this time stay there.
CWI
- 2 sec after the bang, thrust was reduced to idle - no reverse thrust commanded - vigourous braking started and maintained until final stop
Who knows what they saw, could have lost the indications for #1 and #2 and thought using two revereses would pull them off the runway. Maybe they got a fire bell... We don't know, it's all speculation.
Hey Connie Boys I think you all are a class act, watched one of your 747s boom out of JFK last night at 0 dark 30, a clean looking machine,and one of the few classic 747s still earning a living,the truth will all come out ,I don't know why everyone has to monday morning QB this to death,sorry about the thread creep,but this former DC3,Piston Convair,freightdog salutes you,Godspeed,keep those big Boeings flying !
I haven't seen any post here starting with: "They should have", This would be Monday morning QB.
But this is a FORUM after all. And thats what you do on a Forum, you discuss things, and just because you do not like what someone else's post says doesn't make them flamebait or unprofessional or stupid or anything. Read the forum rules.
The "UNPROFESSIONAL" one really is weak and my personal favorite. According to some people, if you post something negative about a company or someone you are suddenly UNPROFESSIONAL??? What on gods green earth has my opinion on the internet with my identity hidden have to do with my JOB??
Totally off subject but had to vent that one. Back to 747 and CK...
hey lighten up there dutchy old boy, no one is threatening to take away your God given right to speculate, my post is strictly my opinion, Cheers !
Umm.. no
Did you read my entire post or do you have reading comprehension problems?
Best thing I have read so far! Thank you!
Funny. You contradicted yourself in your own post. I quoted the part of your post I disagreed with.
And then you contradict yourself and said in that same post.
What I state in my post is exactly what I mean.
At or after V1 the crew is to assume the AC will fly and act accordingly. High speed RTO's are almost always more disastrous than following procedure and continuing.
I stated that the only thing that WOULD keep it from flying would be multiple engine failure. Multiple engine failures on TO are extremely rare. At or after V1 is not the time to start interpreting the problem and try to decide if you should break procedure and give a high speed abort a try with no numbers to give you any inkling of the outcome.
If the preliminary reports are correct, someone just destroyed a good AC that had one engine compressor stalling and could have and should have made an uneventful TO.
Thank God we have the NTSB to do our investigations and not the experts on this forum (but it is pretty intertaining at times). Until you have been a part of one, it is not always as it seems. BTW, the Brussels NTSB is one man! Our NTSB, who was invited to assist, has not finished yet!
