furloughfodder
Membar
- Jan 15, 2004
Avbug, you obviously have done zero research on this program that is sponsored by the Department of Defense, Boeing, and the US Forest Service, as well as Evergreen, who has been in the firefighting business since 1924 and Johnson’s Flying services. Your lack of research is evidenced by your previous post. Nearly everything you said in the first paragraph is either completely wrong or highly exaggerated. You have this vision of them trying to use the Supertanker exactly the same way you operate the current platforms. Wrong.
You talk about them flying at 200 feet loaded to gross at low vis. This aircraft has a pressurized drop system allowing it to fly much higher (800 feet) and deliver it’s payload with minimal evaporation. Even fully loaded with 24,000 pounds of retardant it will be 150,000 pounds under max takeoff weight (that cushion is more than the heaviest airplane you have flown I would guess). It will also be below max landing weight at all times. This means it will not have to dump the entire load before landing. I know when you guys take off it is usually right at MTW. They will be equipped with GPS and Forward Looking Infrared, allowing them to even fly at night to a limited extent.
It will rarely drop its entire payload at once. This is another misconception. It has the ability to drop it in segments. Therefore, it can stay aloft longer, hit multiple targets, or the same one repeatedly. So where a P3 would make 7 round trip flights this aircraft would make one. Sure it will not be able to take off from 3000 foot dirt strips, but it can utilize any number of civil or military strips all over the world, and cruise at Mach .84 or better to get to the scene.
What you don’t realize is the 747 is just an airplane like the one you fly. It may not be as maneuverable, but it is surprisingly responsive. You seem to think all it can do is fly straight and level. If you get away from the delusion that it will be operated the same way current platforms are utilized, you may realize its potential to aid and compliment your work. It will just be another tool, and is not meant to replace the current models whatsoever. Why not encourage and welcome additional help in this arena?
