747 fire bomber
007:
I flew scoopers for fifteen years both North and South America and I can assure you we regularly dropped directly on the fire line. ( mostly the head )
Just as a guess I would say we dropped directly on the fire line in about 80% of the time.
The rest of the time we would have long term on board and of course lay a guard.
That was probably more than 15 years ago...today going direct is infrequent and more often cowboyish. One secures the flanks, seeks an anchorpint, and then begins building line and using other fire tactics.
Going direct on a fire is the most effective way to split a head or flank, effectively creating two or more fires, and effectively reducing one's chances to successfully control the fire. This all depends, of course, on the individual fire and it's circumstances, which are legion.
If you're dropping water, which is far less effective than retardant, the only choice is to go direct. Sometimes it's very effective, but most of the time when direct attack is used, it's only because there are few other choices.
A few years ago we were the only tanker in Florida. We were early in the season. We went to a fire south of Punta Gorda, that was pushing a busy highway, moving south. A state air attack was overhead, and we linked up with him on-site. I did a turn around the fire, and found a structure on the east side that could make use of the retardant. The flame front was close to a mile wide, with 250' flame lengths, rolling hard, and moving with the wind which was about fifteen knots at the time, from the North.
The FDF air attack told us to hit the head, go direct. He knew that news helicopters were in the area, and he wanted the publicity. I advised him that we'd lose the retardant and quite possibly split the head, if the retardant had any effect at all. Our best, and really only true option with the load, considering out turn time, was to lay some protection for the structure and buy it some time.
The FDF ATGS said, and I quote, "This is Florida. That's not our style. In Florida, we hit the head."
It was his call, and we flew down a beautiful clear tunnel beneath the smoke column, directly adjacent to the flames, and hit them with a trail drop, coverage level 8.
Two hours later we were back with another load. The first had split the head, crossed the highway, stopped all traffic, risked numerous lives, and took structures (including the one we identified). Thankfully for us, we were stylish in the best Florida tradition.
Aerial firefighters do NOT fight fire. We support ground troops, who do the real work, and the hardest work. Often that involves backing up a handline, or a cat line. It may mean painting a ridge, or more commonly the backside of a ridge to prevent slopover, or even pretreating a field downwind of a burn to prevent or reduce spot fires. It may mean boxing off a helispot or LZ for troop protection. It may mean many things. But on a large fire, going direct is the least effective means of fighting fires.
Like or not, current, time proven doctrine, and one I live by. Over a fire, the first year pilots are evident when they suggest initial attack tactics, because they're always the ones who want to go direct, and usually to attack the head. The more experienced hands are usually the ones who start putting drops where you might not expect it; right along the flanks or from an anchor point...right where they need to be.
The biggest two exceptions for air ops are helicopters which generally go direct on spots or work flanking fires with helibucket drops, and SEATs (Type III, IV) tankers which do a lot of initial attack work at the very early stages...and often will lay an X over the fire or box it at a single tree or two to prevent spread. This is generally always done with retardant, whenever possible.
In big fire situations in timber, going direct has about as much effect as spitting in a furnace, especially with foam, wet water, or just plain water.
Thank you for the condescending sermon on how to fly water bombers.
Yes I quit the business in 1986, however in the fifteen years that I did fly water bombers no one ever suggested that I was a cowboy, much less indicated that I did not undersand what initial fire attack was all about.
Our method of waterbombing was quite effective, and even in those dark ages we were smart enough to know when it was either ineffective or not safe to continue so we would cease operations.
And isn't it strange that I survived so long making more drops in an hour than most land based pilots would in a day.
Anyhow thanks for giving me a lesson in flying these things.
However it a little late as I very much doubt I'll need the new found knowledge.
And by the way did you do many drops in the Andes Mountains?
If so maybe you could re adjust my lack of knowledge in that enviorement also?
Cat Driver
If it was so **CENSORED****CENSORED****CENSORED****CENSORED** effective, mate, you wouldn't have had to do that many drops.
Think about it.
As for the "dark ages," there's a reason that the statistics are much better today than they were 10, 20, and 30 years ago. It's not luck.
The Andes hold some special technique that's only applicable to that chain of mountains, perhaps?
And yes...I have.
Ah well, I guess I shall bow to your superior skills and knowledge.
Hey, I am now teaching pilots how to fly large flying boats for a living..
Can you maybe take some time to give me some pointers on where I am lacking in knowledge in that area as well?
Cat Driver:
Don't take it personal Cat Driver. Avbug is an expert on a lot of things.
Avbug, we realize you have vast experience fighting fires, but just curious how much 747 time you have? You seem extremely knowledgeable about the inadequacies of this aircraft and its use as a fire fighting platform.
Tell me this, mate. I see you fly the 747. How much time have you got flying it low and slow, 200' at landing airspeeds in mountainous terrain in zero visibility in extreme turbulence with large objects flying about, loaded to gross? Do it in formation flight with dissimiliar aircraft, with up to 50 others nearby (hint; you might need to maneuver suddenly). Then turn around and buster home, for the fastest hot turnaround of your life. While you're at it, be prepared to work on it; you'll be doing a lot of the maintenance. You'll need a support squadron to follow, of course...but is it sounding like your cup of tea, yet?
Wanna give it a shot? You do that; you go fly in the fire environment and then tell me what a great platform you think it will make.
You then go down on the fireline and work a few seasons. Get hit with a drop or two. Tell me how you feel about getting sixty thousand pounds of water in your face, coming hard at 150 KIAS. Then tell me how appropriate that kind of a low level load is for the fireline.
Catdriver, I see your site indicates you're providing PBY training. Must be a big market for that...especially as you require the customer to provide the airplane. I'm not going to tell you how to teach...so long as it's not teaching firefighting. If you are, then it's probably time to attend class before getting back in the game. The game has changed...considerably for the better.
Avbug:
:D :D I would never dare to put myself in your category. :D :D :
I don't think I would live long enough near the expert you are.
By the way an expert is a " has been, drip, under pressure "
You take care now and dont hurt yourself banging that big head into hard objects. :D
Furlough..... Avbug is delusional, probably loads the tankers and hears wrong in the bar after hours.
Cat Driver:
Crap, I just spent way too much time reading this thread. This site is like crack...even when its a stupid argument like this.
take it from those that know
I spent four years on the ground with a USDA hand crew. Over the years I heard a million plans to change aerial firefighting. Some (like the A-10 tanker plan) were solid ideas worth researching further. I can honestly say (as a former wildland firefighter turned pilot) that this 747 tanker program is the worst thing I've ever heard. I agree that evergreen is a great company, managed by very intelligent people that know the performance capabilities of the 747. However, they’re not firefighters. The last few years have been disastrous fire seasons and evergreen sees the profit potential available in the chaos. They are interested in money first, product second. If they weren’t they would be listening to firefighters (and the forest service) and be developing smaller, more maneuverable tanker platforms. Aerial firefighting from it's inception has been a work in progress. Every year it's re-evaluated for effectiveness, and changed if needed. The USDA is starting to see what CDF did all along, smaller is better. The SEAT (single engine air tanker) program has grown drastically in the last few years and is more popular than ever. From a ground pounder standpoint, 800-2000 gallons used properly will be much better than 10,000 gallons spread all over the country. If you think a 747 can do the things that today’s tankers (P3's, P2's, PBY's, S2's) are doing, then your sadly mistaken. I've seen P3's run down ridges, 70 degrees nose down, dump their load and skim the tree tops on there way out. Not to mention seeing P2's running through a saddle ridge, straight at a mountain, dump and turn in time. There is no 747 plane or pilot that can do it. What do you 74 drivers think, you just hit the dump and fly straight and level for 5 miles? Sorry, it doesn't work that way and of the thousand or so fires I've been on, not one of then burned straight or over flat ground. A wildfire is not won from the air, it's controlled by the men and women on the ground that scratch a line in the dirt. A tanker has to support that line. A line that snakes across, up and down the mountain. In the last 30 years the USFS has used countless aircraft types for tankers, while CDF has (and continues to) use one. Who do you think understands the role of an airtanker? Evergreen should've put that 747 money into researching what firefighters wanted all along. A solid, highly maneuverable tanker carrying about 1500 gallons. I personally think the A-10 or C-2 Greyhound warrant serious consideration and should be researched as potential platforms. The so cal fires last year, and the huge arizona fire 2 years before has created such a panic, people believe we need a giant tanker of water above us. But what the %&^$, it's just our tax dollar hard at work, right?
Actually, Evergreen has a solid firefighting heritage operating heavy tankers. Tanking an airplane isn't a new endevour for them.
The A-10 program was originally a CIA program to funnel aircraft to foriegn interests. The more recent effort was nothing more than ex A-10 drivers trying to create a job niche for themselves. It never had any real promise.
Avbug, you obviously have done zero research on this program that is sponsored by the Department of Defense, Boeing, and the US Forest Service, as well as Evergreen, who has been in the firefighting business since 1924 and Johnson’s Flying services. Your lack of research is evidenced by your previous post. Nearly everything you said in the first paragraph is either completely wrong or highly exaggerated. You have this vision of them trying to use the Supertanker exactly the same way you operate the current platforms. Wrong.
You talk about them flying at 200 feet loaded to gross at low vis. This aircraft has a pressurized drop system allowing it to fly much higher (800 feet) and deliver it’s payload with minimal evaporation. Even fully loaded with 24,000 pounds of retardant it will be 150,000 pounds under max takeoff weight (that cushion is more than the heaviest airplane you have flown I would guess). It will also be below max landing weight at all times. This means it will not have to dump the entire load before landing. I know when you guys take off it is usually right at MTW. They will be equipped with GPS and Forward Looking Infrared, allowing them to even fly at night to a limited extent.
It will rarely drop its entire payload at once. This is another misconception. It has the ability to drop it in segments. Therefore, it can stay aloft longer, hit multiple targets, or the same one repeatedly. So where a P3 would make 7 round trip flights this aircraft would make one. Sure it will not be able to take off from 3000 foot dirt strips, but it can utilize any number of civil or military strips all over the world, and cruise at Mach .84 or better to get to the scene.
What you don’t realize is the 747 is just an airplane like the one you fly. It may not be as maneuverable, but it is surprisingly responsive. You seem to think all it can do is fly straight and level. If you get away from the delusion that it will be operated the same way current platforms are utilized, you may realize its potential to aid and compliment your work. It will just be another tool, and is not meant to replace the current models whatsoever. Why not encourage and welcome additional help in this arena?
HA! HA! HA! HA! HA! HA!
Fly to the fire at Mach.84 !!!!!!!.....HE!HE!HE!HE!
Oh man you crack me up.....
I can't remember the EXACT average dispatch distance to a fire but it's aroung sixty miles I believe.... Mach .84..he he he
What about the 250kts below ten thousand feet rule?
Imagine this eh avbug?
"747 N123 you're not lined up properly , go around and follow my lead" ..... another ton of pollution puked into the air..three mile wide cuircuit.... better clear the surrounding ten miles of other tankers and support aircraft.
How the hell are you going to see out of this beast going downhill with the nose up? Beats me.
But then again , I only have twenty five years flying tankers... what would I know?
"Lead 45 , this is 747 N123 , we're inbound with a load , leaving FL350 , what's our target today?"
"This is lead 45 , um ... you're target for today is Montana"
"N123 copy , copy. Yep! we did Idaho yesterday , are we doin' Californy tommorow?"
"N123 , this is lead , cleared in , we have evacuated all other tankers for a five mile radius and all helicopters are on the ground and ground personnel are being flown out in Hercs , so it's all yours."
On a more serious note , did you know that retardant on healthy trees renders them DEAD after a few years. It blocks the ability of the needles to convert CO2 or something... I forget the details.
Walter P. once told me you can be ignorant or arrogant in this business, but you cant be both....................
DC4boy:
We have living proof you can be both ignorant and arrogant right in this group.
All you need do is go back and read Avbugs comments on my Flying boat training business and there you have the perfect example.
All that needs to be decided is is he mostly ignorant or mostly arrogant? :D :D
Yup DC4boy :
Me thinks a few minutes in a PBY on the water may be a good start to let some air out of Avbug. :D :D
Duke,
I respect you and I enjoy reading your tales of aviation. Very entertaining. Keep up the good work.
What I meant by .84 to the fire was that one of the reasons people think the 747 will not work is because it can not operate out of the same small strips others can. However it can reload at bases further away and make up for the distance with speed.
Also, it can be positioned to a fire in another part of the country (or world) much faster.
I hope you really don't think I meant it would drop retardant at .84. Remember: it will be traveling at stall speed, and max gross weight when dumping. ;)
furloughfodder ... no offence sir , no offence...
I was just having some fun... I thought it would get more laughs.
I have a very good idea as to how they intend to operate the 747 and here in Canada there was an attempt to try a 737 but the idea was dropped in favour of the Electra L188 , the old but still effective DC6 and the new concept , the Convair 580.
Usually when approaching a large fire the tankers are given altitudes in the stack above and await your turn to be worked on the fire. I have orbited fires with six Invaders , two L188 and a DC6 all stacked up 500 feet apart.
What happens when the 747 shows up? I dunno . Does everyone have to flee or does he loiter in the stack awaiting his turn?
It sound like he can puke a LOOONG load over miles... too bad the fire line is never conveniently straight... it's all over the place.... up and down hills licking this way and that.
I guess if you wait long enough , a fire will appear in the right terrain with a mile long straight firefront., with no smoke .
As far as the 747 being able to operate from airfields further away because of it's speed....same thing as more versatile tankers operating out of more airfields closer to the fire and with more proper sized tankers you can fight many fires at once.
Can you imagine spending those bucks on re-engining aircraft like the Neptune with bigass Allisons ... now there's a tanker.
A 747 thumping around in low level turbulence...Hmmmm....not really designed for this role I would suggest.
Duke,
I agree with you. Hangin a couple Allisons from a P-2 would be great. Also, a turbine DC-4 is in the works as we speak.
Saab 2000 and -8 Q400 are on the table as well.
In my humble opinon, the only way to fight fire is initial attack.
CDF responds 10 engines, 2 dozers, 2 crews, 2 airtankers, AA and a helicopter within 5 min of the first report. Many units respond to over 400 fires a year, and for that reason, you only hear of a few big ones when the Santa Annas blow.
Ask any firefighter. Initial attack is from 0-15.
Aircraft to be effective" must" be used as soon as a smoke starts.
The best system I ever worked under was Manitoba.
I was given an area to protect, we were self dispatched by beeper / FM Radio / Phone what ever means forestry chose to contact us. We were allowed to determine our stand by alert status, and never missed a dispatch because we were not ready.
Every report of a possible fire was acted upon, and quite frequently were false alarms such as dust off a northern road.
However our sucess rate at holding new fires was exceptionally improved over the method of needing fifty different people to make up their mind to dispatch the tanker while the fire got bigger.
I have always felt that many small initial attack machines such as that new Fire Boss single engine turbine on Amphibs would be excellent tools in the control of new fire starts.
And anyone who scoffs at the efficiency of a water scooper dropping on a new fire start every three to six minutes, obviously has never seen what can be accomplished.
"BUT" fires are put out by ground crews...aerial attack is a holding method.
I agree Cat Driver.
As soon as the USFS decides to fight fire agressively, things will change and fires will be less of a problem.
I cant tell you how many time we continued to paint a mountain side while crews were "de-mobing" at 5:00.
We all know that dosent work.
Avbug quoted above "Aerial firefighters dont fight fire"
I beg to differ............................
avbug said:
I've worked with canadian CL215's and 415's on fires on both sides of the border. Scoopers have merit where there is ample water, but there are many locations where they don't. One thing I did note when flying across the border in regions where the use of scoopers was the rule was that the birddogs had seemed to have no real concept about the proper use of retardant.
Having lost another tanker pilot yesterday, I'm not in a humorous mood. One is always too many...but it seems that it's all too frequently one too many.
I will kill you Avbug if you go get yourself killed!:D
No, Be careful, it would be a tremendous loss if something were to happend to you.
ALL you FLYING FIREFLIES be careful!
