737 Crash Near Athens
Dangerkitty said:
After your 757 T/O comment that caused so much ridicule I thought that you wouldn't embarrass yourself by making it again. Yet I am wrong.
Do you not realize that you are pulling 1G right now as you sit at your computer?
Hahaa. I thought I had sufficiently explained that already, but since some people weren't paying attention.....
A pullout of more than one G implies 1+ G's. If it was 2 G's, which it wasn't, I would have said 2 G's. Sadly, on that particular day I left my accelerometer at home.... otherwise I could have given you a more accurate figure, which you would have disputed.
No, I don't actually have an accelerometer.
I referenced the 1+ G thing AGAIN to get a rise out of you guys, and it worked. Imagine that.
Incidentally, I am currently pulling more than one G (1+ G's you might say) in my chair 'cause I'm LMAO.
EagleRJ said:
Something strange about this accident is the fact that the tail section survived intact.
That implies something less than a high-speed, high-angle impact after the aircraft either ran out of fuel or went out of control with no one flying. It suggests a slower speed at the time of impact, in more level flight.
If that's the case, why didn't the aircraft spend enough time below 15,000' or so for the pilots to regain consciousness and regain control?
Something's strange here....
It is strange. Maybe a 737NG pilot could comment on the autopilot VNAV function. If it is engaged after takeoff, will it initiate the VNAV descent only after pilot input to the FCP, or will it simply fly the VNAV altitudes in the FMS? If the latter is possible, then the airplane simply desceded at TOD, ended up holding at the last waypoint in the FMS, and ran out of fuel.
The events leading up to this probably started in the climb phase, and the pilots were not alive after extended flight at altitude. Not sure about 2 people sighted by F-16's in the cockpit. Were they F/A's using portable Oxygen?
Dreadful thing if that were the case...
if it were a decompres., wouldnt the windows be fogged like in payne stewarts case?
They are reporting that the FO was slumped over the column with his 02 mask.
They are also reporting the captain was not in the cockpit visual from the fighter jets.
Also they said early on that an SMS had been sent from a pax stating the captain was passed out and turning blue.
Of course it's the BBC so what can you expect.
You don't have to explain anything to me junior. I have been flying aircraft quite long enough to know that I don't need explaining from the likes of you.
How do you know it was between 1G but less than 2G's? By your own admission you left your accelerometer at home. Which now you admit to not having.
We are always at 1G unless we are weightless, pushing negative G's, or actually pulling more G's such as doing steep turns or aerobatics.
You didn't get a rise out of me. Quite the opposite. Posting the crap that you just posted just makes you out to look like a 40 hour student pilot tool. Oh wait, you are a 40 hour student pilot tool.
Enjoy the laugh. (It doesn't make you pull more G's though) After reading more comments from you it is apparent that you have no clue what you are talking about. Time to get some more dual in your Cessna there junior.
9GClub said:
At least one source suggested that the Greek Vipers only saw one pilot in the cockpit, which implies that the other one may have indeed been prancing in the aisle.....
It also seems like a few technically apt (or at least curious) passengers-- if they weren't incapacitated-- would have checked out the cockpit to see what was up. If I was conscious I'd at least try to save the day with a glorious last-ditch 1+ G CFIT-avoidance maneuver.......
Perhaps the passengers could not get into the cockpit for the same reason the Captain could not if the F/O was incapacitated....the fortified cockpit door that cannot be unlocked from the cabin. Keeps hijackers out OK though! ARG!
~DC
More news about the accident from the report linked above:
"Greek media speculated a toxic gas from possible faulty air-conditioning could have incapacitated the two pilots before they knew they were in danger."
Great! Now we have the media speculating about "toxic gases" from faulty airconditioning. I bet the next educated statement that they are going to make is that freon got into the packs.
Dumbasses.
Dumbasses.
Actually, I think this is the scenario that makes the most sense. (not freon of course, but air contamination). It is certainly possible to get contaminated bleed air.
Passengers were saying it was "freezing". Which implies that the automatic temperature control was having problems, or perhaps that both packs were inop(?)
Maybe suspected air conditioning smoke in the cockpit followed by deactivating the packs. This depressurizes the plane slowly, everybody goes on oxygen, and it gets cold as hell. The captain decides to go take a walk around, and collapses in the cabin, and the copilot passes out from the burning circuit boards or whatever he inhaled... The airplanes flies in level flight into rising mountainous terrain and that's why the tail survives. The cockpit door prevents any hero passengers from saving the day, even if they realized to copilot was passed out.
KigAir said:
Here's another news story with talk of charred bodies. If the plane ran out of fuel would there still be fire?
http://wireservice.wired.com/wired/story.asp?section=Breaking&storyId=1075856
There could have been fuel remaining depending on which tanks it was in and which fuel pumps were on.
DC-9's will not suck fuel from the center tank but I do not know about 737's.
We'll see, it will be determined in the investigation. Puzzling accident though.
~DC
KigAir said:
Are the cockpit and passenger O2 masks fed from the same source on the 737?
Nope. The pax have the chemical candles installed overhead each row of seats that release oxygen after the mask is pulled to start the chemical reaction. The pilots have a standard tank. As for the VNAV question, you first have to set in a new altitude in the MCP for VNAV to take you down. Could a passenger have seen the 35000 set in and dialed it down? Maybe. That would then take the airplane down at TOD. As for the fuel, most likely they had all six pumps on and the airplane would burn completely dry.
Looked like a short flight...wouldn't the center tank be empty and the center pumps turned off anyway?
Could be, I'm not sure how long a flight it was. Whether or not there was center tank fuel, the airplane would most likely burn dry if the pilots were incapacitated at any given moment. Unless, they took off with less than 5000 lbs in the center tank and the pumps didn't have the mod, then they would have center tank fuel but the pumps would be off until 10000 feet. It sounds like these guys got to 35000, though, so that isn't likely. I would say the odds were excellent it was configured to burn dry.
Automation-yes. Lowest safe altitude GASP, Level Change select WHEWGASP, Speed Br.......EX........Wait I forgot something..........Blackness.(Four minutes later at 10,000 feet)
Sir, Sir all you alright this is your number 6 FA, here put this O2 mask on ...........
737NG-Remembet the MCP(Master Control Panel) overrides anything and everything set in the FMC/VNAV. The only way the FMC would be in control is if the DH is set in the MCP window, then the VNAV would fly the airplane to the runway as long as everything had been properly programmed.
I am going to have to disagree with you on this on ACK. With bleed air problems there is usually smoke and odor. If that were the case I would hope the crew went to 100% O2.
I really doubt this would be the problem. You cannot fly the B-737 above FL 250 with one pack inop. If the auto controller was having problems it would be very easy to go to manual control. However I really dont think that this is the problem.
I doubt it. If you shut off both packs you are going to go down as low as you can. If the altitude is above the norm the Captain should not be walking around the "check things out". That is what the FA is for. If the Pilots are on 100% O2 then it should not matter if there are burning things around them. They should be able to breathe and take care of the task at hand.
Whatever happened it is a very bizarre accident. I am anxious to hear what happened on the tapes.
