737 climb performance (after T/O)
SMOOTHRIDE
Hello All;
It's been a while since higher power, and my study materials for the 737 don't include performance charts (mostly systems and procedures). What do the 737-300s and various NGs have for typical climb performance at gross weights and lighter (at about 20-25 deg C, Sea level)?
I tried a search but it was fruitless...
Many thanks for input!
SMOOTHRIDE said:
Hello All;
At MGW I would say 1500-2500 FPM till approx FL230-250, then about 500-1500FPM after that...
There are a lot of other factors that drive it...
The NG's are generally a lot better than the classics. The -700 is a rocket ship as it'll climb out 1500-2000 fpm full near MGW all the way to 370. If you want higher than that then you'll need to burn off some gas. The -800 does pretty good to 340 full and near MGW, but 340 is the ceiling until you burn some gas. The classics are slower with the -500 doing slightly better than the -300 only because it is lighter and has the same motors.
Cheers
Thanks plug and shields,
Do you know of a website that has 737 performance data (besides the 737 technical information UK website)?
So to summarize, it's about 1500-2500 fpm at approx. gross weights at about 70 deg. at sea level?
Thanks again for the responses, I know this is a somewhat general question, but it's just for thumbnail sketch ideas...
SMOOTHRIDE said:
Hello All;
737-400, CFM56-3B2 Engines, Max Climb Thrust
280 KIAS/ M .74
130,000 lbs, Time/Fuel/Distance to FL 370 ~ Standard Atmosphere
25 minutes/4075 lbs./154 miles
Avg. feet per minute = 1640
Cool, You guys Rock!!!!
Many thanks my friends, that's good data!
In the 300 sim (at training weights), after liftoff, and before accel. height (prior to reducing pitch and accel for flap schedule),
the vsi seemed pretty high (maybe 3000 fpm or close to it)-- is that possible?
Nope..about right if you are truly flying the FD.....
Domo Arigato Y'all
Many thanks again! I swear this forum is always entertaining and sometimes useful, this time it was very useful!!
Beers
Of all my transport aircraft experiences, the 737-800 is third behind the 757 and 777 in climb. It does a good job despite having French engines.
The 777 of course varies with the fuel load, but for domestic its a rocket. Tokyo, not so much.
SMOOTHRIDE said:
In the 300 sim (at training weights), after liftoff, and before accel. height (prior to reducing pitch and accel for flap schedule), the vsi seemed pretty high (maybe 3000 fpm or close to it)-- is that possible?
Not at all unusual. Consider that once you're established in your second segment climb, you're pitching somewhere in the neighborhood of V2+10 - V2+15 with two engines running (20k#/thrust each) and the wheels up.
For what it's worth, at MGTOW the 300 weighs 3.375 pounds per pound of thrust, while the 700 weighs 3.192lbs/lb thrust. However, when the 700 is flown at stage lengths typical of the 300 (and thus not nearly 20,000 # heavier) the ratio is 2.789... a rocketship to say the least. Doing ICAO A departure profiles in a 700 (SNA, DCA, etc) it's not unusual at all to bury the VSI at 6000 FPM until you pitch for acceleration.
ATR,
At 6000 fpm (or more) things must be happening pretty fast...
Most I've done is 3500 fpm (not so sustained).
The -700 out of SNA does awesome. You can't blink during the takeoff or you miss a couple hundred feet whizzing by...
Can't wait to do it in a 757...
