eaglesview
- May 5, 2008
Regardless, i'm confident with my JD degree and knowledge against your incessant rambling which one actually has merit within the discussion. W2 figures are the benchmark data used within these proceedings not your "point" no matter how many times you want to whine about it. You also realize that the SLI process has already started with discovery on both sides right?
Also, if you are going to call someone a fool, be sure to at least spell correctly (thet?) and understand the difference between your and you're. Maybe you should stick to brain surgery?
First off thank you so much for the english lesson. Thet was an obvious typo and your was a mistake....you were correct I was wrong....shoot me. You are the one that started the name calling read your (did I get that one correct???) own post. At the time of the W2 request there were no proceedings going on. It was a ploy plain and simple. If you want to believe other wise feel free. You have that right, but you know all about rights with your dusty ole JD degree. Pompass A$$
