X or 680 time? -Northrop Grumman job
  • Thread starter Thread starter Rough67
  • Watchers Watchers 2
Rough67
5 t's
Hey now...
Found this on www.avcrew.com and thought some of you NJA guys on furlough with X, or 680 time may want to give it a shot. Good luck ...
https://ngc.taleo.net/careersection/ngc_pro/jobdetail.ftl
Pilot 5
Requisition ID
: 11006630
Business Sector
: Corporate
Location
: United States-Virginia-Dulles
US Citizenship Required for this Position
: Yes
Relocation Assistance
: Relocation assistance will be available
Clearance Type
: Secret
Number of Openings
: 1
Shift
: 1st Shift
Description
Pilot-in-Command of Citation 680 and 750 aircraft in corporate flight operations. This position is based at the Washington-Dulles International Airport (IAD). Pilots will be required to perform other aviation-related administrative duties assigned by management.
Qualifications
Basic Qualifications:
Minimum flight experience required is 4,000 hours total, 1,000 hours turbine, 500 hours jet and 250 hours in the last 12 months. FAA multi-engine Airline Transport Pilot certificate and Class I medical certificate with no waivers is required.
U.S. citizenship is required. Must be eligible for a DoD security clearance. An FAA pilot record check and a security background check will be performed. Pilots in this position participate in an FAA-approved drug and alcohol screening program.
Preferred Qualifications:
FAA type ratings in CE-680 and/or CE-750 aircraft and 500 PIC hours in type is preferred.
Northrop Grumman Corporation is a leading global security company whose 120,000 employees provide innovative systems, products, and solutions in aerospace, electronics, information systems, shipbuilding and technical services to government and commercial customers worldwide.
Northrop Grumman is an Equal Opportunity Employer committed to hiring and retaining a diverse workforce. U.S. Citizenship is required for most positions.
Send this job to a friend
Send this job description to a friend by email. All the relevant details will be included in the message.Send this job to a friend
I saw one of their Citation Xs takeoff out of Hawthorne Airport near LAX awhile back. Used up a lot of that runway....
If you live in the Dulles area, prepare to pay through the nose for homes if you are buying. I guess apartments wouldn't be too bad.
