Wingtip vorticies: Their benefits?
I don't like A Squared. sounds like this FastestPA something or another user on here. I got your back Rush. You messed up and said so. I can't count how many times I've told a student to pull back on the rudder. :O
Quote:
Originally Posted by The_Russian
Not entirely. I should have clarified my position. For some reason I thought we were speaking directly in reference to winglets. I must have read the first post wrong.
Right, you "misunderstood":rolleyes: You thought the question asked about winglets
Sure, that's why you wrote
Quote:
"Wingtip vorticies help to reduce induced drag by increasing the lateral flow of air over the wing."
Uh-huh, you wrote "wingtip vortices" because you really meant winglets.
Look, it's very clear what you meant, and you clarified exactly what you meant in your second post. Now you are trying to claim you didn't really say that and it's all a big misunderstanding.
Or......you could talk about what we are talking about. Look man. You got some kind of problem with me or something? Did accidently poop in your cereal or have sex with your daughter? Get a life man. I messed up and said so. I have never seen you conceed to messing up. According to yourself you "know everything". I typed one thing while I was thinking another. And please, don't give me that crap about "Russian doesn't know what Russian's talking about". I did extensive research on winglets and wingtip vortices at my University. And, it was all done in a sub-sonic wind tunnel. Take that back to basic aerodynamics school.
I don't either. A Squared brings down the quality of the board. A Squared does not post in a positive manner. A Squared also does not post correct information and claims that it is, on a regular basis. After posting, A Squared will make derogitory remarks to others to try and make himself sound correct.
Good luck A Squared. I hope you find happiness somewhere.
Russian
You guys take this trivia pretty serious.
Remember that in flying it is not WHAT you know but WHO you know that really matters.
Illini Pilot said:
induced drag is related to AOA, not really speed.
And AOA isn't related to airspeed?
How pathetically juvinile can some of you get? Whatever depth you intend to sink, you're doing well.
A Squared has been posting here for a long time now, before this board was in it's current generation, and the one before that. I don't believe I've ever seen him post frivolously. I also keenly admire his tenacity in driving home a point. His are routinely among the most accurate, germain, and well written posts on the board, and long have been. If you don't like it, perhaps you ought to do a little more research before you open your mouth. He doesn't cut you much slack, nor should he. Get over it.
And danged if you still weren't wrong. Some people's kids.
And here we thought junior high was out for the summer. Go figure.
Not particularly surprising, now that you mention it. You probably shouldn't mention it too much, though.
Looking back at your previous posts on this topic, I hope you didn't actually graduate from your "University."
You had "extensive research" in a sub-sonic wind tunnel?? Did they actually turn the blower on?
cathaywannabe said:
O.K. smart guys - here is another question.
As an airplane slows and maintains straight and level flight, will induced drag increase or decrease?
induced drag increase,
parasite drag decrease
Are you really asking this private pilot level question? Or do you have some wierd twist on this?
By the way, the induced drag is also attributed to the rearward horizontal component of lift at a high angle of attack.
I just like seeing heavies come out of the clouds on a humid day, beauty eh?
Airspeeds ABOVE and BELOW L/Dmax will increase TOTAL drag.
BELOW L/Dmax, total drag is increased due to induced drag.
ABOVE L/Dmax, total drag is increased due to parasite drag.
Airspeeds at L/Dmax provide the greatest amount of lift for the least amount of drag.
Concerning your question directly, lift is generated (all things being equal) and is a function of, airspeed and AOA. You must compensate with one when the other is taken away in order to generatethe same amount of lift. As you decrease your speed while maintaining altitude, you will need to increase the angle of attack (AOA). By virtue of increasing the AOA you are increasing the amount of induced drag being created. Since you are not creating lift with an abundance of airspeed, you will need to inevitably increase the AOA.
When you increase the AOA, you create a greater pressure differential between the upper and lower part of the wing. Lower pressure on top and relatively higher pressure below. This greater inqueality of the two pressures casues a greater span wise movement of the higher pressure which seeks out the lower pressure above the wing. This air moves outward towards the wingtips where it meets with the lower pressure above the wing and bends the lift vector backward. An easy way of visualizing induced drag is by imagining the wing at an exagerated AOA. While visualizing this, think of the lift as being perpendicular to the wing, not the flight path. If you do this, you'll see that the lift is acting backwards or rearwards rather than striaght up. This rearward pull or dragging, is what induced drag is.
