OK RoughAir, I'll try to combine all the previous into a coherent answer for you. Your profile is not very specific, so forgive me if I'm talking below you. Also, I'll admit I have all of 1 hour in the Van, I'm speaking from my experience in general. The Caravan has 2 problems: first, it's not very fast to begin with, and second it has a lot of stuff to collect ice, ie wing struts, fixed gear, cargo pod. The point is, the first thing that happens in ice is that you lose airspeed. You need a lot of wind to blow the ice off the boots, so if you just lost of bunch of speed which you didn't have to begin with, you're SOL. (I liked the climb/dive trick, that could be useful in several aircraft.) That's the biggest part of it right there; it's just not fast enough, and loses too much speed too quickly. You don't have the margin for error that you would in other planes. I believe the proposed AD's are aimed at making sure the aircraft is properly deiced on the ground before take-off, so as to preserve whatever margin of error there might be. Like the Challenger, if you take-off with ice already on the plane, you're cutting it really, really close.
