When Will CAL Vote?
BID
When will CAL vote on the new TA?
If I recall correctly, the hourly pay rate would decrease by 9%?
According to airlinepilotcentral.com, the pay is divided by aircraft into SN, LN, Wide
Which aircraft are in the SN, LN category?
thanks for the info.
Voting ends at the end of March. Interestingly, the domestic 752 and 753 actually carry more people than the 762.
Small Narrowbody
737-300
737-500
737-700
Large Narrowbody
MD-80
737-800
737-900
757-200
757-300
Wide Body
767-200
767-400
777-200
Results will be out March 31 specifically. Voting ends March 30.
A little more on the pay issue. We have 3 equipment sub bases. The 737 base flies all of the 73 models. The 75/76 base flies all of the 757 & 767 models and the 777 base obviously flies only that aircraft although the 787 will probably be a common type rating with the 777 and therefore become part of that base.
The pilots sub bases that fly multiple aircraft in more than one pay catagory get a blended rate for any pay not associated with acutally flying the specific aircraft. Currently the 737 pilots get 50/50 NB & LNB blended rate and the 75/76 pilots get 60/40 the LNB & WB rate for training, reserve, DH........etc.
This is the same as the current contract, no change if the TA passes.
