TIS
Wing, Nosewheel, Whatever
- Dec 19, 2001
TonyC said:Such practical application (needles, bearing pointers, etc.) has no place with a DME ARC, and it still doesn't give us a reference.
Okay then, hows about you do a little legwork too! I found this in about three minutes. Here's your course width info for an arc when used as an intermediate approach segment.
From FAA Order 8260.3b, Change 19
243. INTERMEDIATE APPROACH SEGMENT BASED ON AN ARC. Arcs with a radius of less than 7 miles or more than 30 miles from the navigation facility shall NOT be used. DME arc courses shall be predicated on DME collocated with a facility providing omnidirectional course information.
a. Alignment. The same arc shall be used for the intermediate and the final approach segments. No turns shall be required over the FAF.
b. Area. (1) Length. The intermediate segment shall NOT be less than 5 miles nor more than 15 miles in length, measured along the arc. The OPTIMUM length is 10 miles. A distance greater than 10 miles should not be used unless an operational requirement justifies the greater distance. (2) Width. The total width of an arc intermediate segment is 6 miles on each side of the arc. For obstacle clearance purposes, this width is divided into a primary and a secondary area. The primary area extends 4 miles laterally on each side of the arc segment. The secondary areas extend 2 miles laterally on each side of the primary area (see figure 10).
Here’s the link if you want to pour over more of it than this.
http://av-info.faa.gov/terps/directives page.htm
And from the AIM:
The term “established” means, “To be stable or fixed on a route, route segment, altitude, heading, etc.” (AIM – Pilot/Controller Glossary under “E”). Nothing more and nothing less.
TIS
