PropsR4Boats
- Mar 23, 2005
OK, Props. If it's so easy, give me a number and a reference, please.PropsR4Boats said:You guys make me laugh. You make it so hard. Have your instructor go over it with you, and keep reading your AIM and instrument procedures book. (that’s a new book put out by the FAA)
Reading and applying helps you figure out what to do on other tricky procedures. Soon you will be briefing an approach a couple minutes before you start it. I promise this way is the best way. Just read and look at a bunch of approaches then chair fly'em.
Uh huh. I'm with ya.prpjt said:+/- 1 mile is in my AIM now. Let's go eat.
The only place I've ever seen +/- 1 printed is in the PTS.
I meant to say Initial Approach Segment, but I left out a '0'
Protected airspace on the initial segment is 4 miles lateral and a 2 mi. buffer.
Controllers can have aircraft on arcs 10 miles apart within 35 miles of the station.
None of this answers the question "What is established?"
PA31Ho said:Okay, so now let's say you are going straight for WANDO intersection from the east. You align youself with the CHS 155R outbound, hit WANDO, do the teardrop. If ATC says "let me know when you are established in the hold," when are you established? After passing the intersection and doing the teardrop? Or once inbound on the 235R?
MTpilot said:Yeah but......I'm squawkin 7600.
PA31Ho said:See, I would think 'established in a hold' is after crossing a fix regardless of which type of entry.
CFI4LIFE said:You would be correct! The AIM says you must report the time and altitude/flight level at which you reach (or depart) a clearance limit. It says nothing about reporting when on the inbound leg.
Singlecoil said:We need Vector4fun here because I believe the amount of airspace they protect shrinks slightly after you report "established". A parallel entry in particular can take you a little wide in the pattern, that's why I'm thinking "established" is when you have intercepted the desired radial/course and are tracking it inbound.
You're established, in your scenario, when you're on the arc. That means when you're at 12 miles. The +/- stuff is a PTS standard that is not applicable to anything but a Practical Test. You're supposed to stay at the correct distance all the time.TonyC said:When are you established?
This is correct. The protected airspace does indeed shrink when you are established in the hold.Singlecoil said:We need Vector4fun here because I believe the amount of airspace they protect shrinks slightly after you report "established". A parallel entry in particular can take you a little wide in the pattern, that's why I'm thinking "established" is when you have intercepted the desired radial/course and are tracking it inbound.
However, CFI4LIFE is correct about this:CFI4LIFE said:The AIM says you must report the time and altitude/flight level at which you reach (or depart) a clearance limit.
CFI4LIFE said:It says nothing about reporting when on the inbound leg.
