What's up with the 2 D cell flashlight?
Whiskey Tango
I am trying to find were exaclty it says that under part 121 you need a D cell flashlight. Part 91.503 requires it for part 91 ops and 121.549 just says "a flashlight in good working order"
Unless I am missing something I can use the watch battery LED flashlight in my pocket for 121 ops and the old mag light for 91 repo legs.
Thanks for the help
Doesn't it also say "...or equivalent."? Which begs the question: Equivalent in what manner? Duration of use? Brightness? Range? Or something other thing?
Usually (not saying this is the absolute truth) when talking about flashlight equivalents, you are talking about battery voltage. A D-Cell battery puts out 1.5 volts, therefore 2 D-Cells = 3 volts. A mini mag lite uses two AA-cells. One AA = 1.5 volts. So you could say that an equivalent to a 2 D-Cell battery mag light is any flashlight that uses two batteries that put out 1.5V each, i.e. a battery with 2 D-cells, C-cells, AA's, AAA's, whatever. I could be wrong here, but that's how it was explained to me.
Thanks for the help
You can look all you want, it's not in there anymore.
My company (121) only requires a flashlight. Doesn't have to be a D cell, and can be as small as you want.
Chperplt is correct.
Thats becuase there is no such thing as a D-cell flashlight anymore. They dont make D-Cell Batteries anymore.
I went round and round with a Fed with this one. I won, he lost. :p
I just spent a whoe night putting D-cells in everything from Gorilla Attack to ESPN shoot around ( NOTE: SHUT UP DICKIE V). I don't think the kids know what a pain batteries are.
Was I mistaken that they weren't "D-CELLS"?
Look again. On the battery it will not say "D-Cell" it will say "D-Size"
Trust me on this one folks I went toe to toe with a Fed on this one and I won. Back in the day D-Cell flashlights were infact required under Part 121 regs because they provided adequate Candlelight power.
Now since technology has caught up they are no longer required because:
1. Cell batteries are not made anymore. (Not the way we think of them anyway)
2. A flashlight with C-Size or in some cases even AA-Size can provide the same amount of Candlelight power of the old D-Cell batteries.
Once again look on the battery. It will say D-Size. Thats becuase there is no such thing as a D-Cell battery anymore.
From wikipedia
Cell vs. battery
Strictly, an electrical "battery" is an interconnected array of one or more similar "cells". That distinction, however, is considered pedantic in most contexts (other than the expression dry cell), and in current English usage it is more common to call a single cell used on its own a battery than a cell. For example, a hand lamp (flashlight) (torch) is said to take one or more "batteries" even though they may be D cells. A car battery is a true "battery" because it uses multiple cells. Multiple batteries or cells may also be refered to as a battery pack as a set of multi-cell 12 V batteries in an electric vehicle.
taloft said:
A 121 pilot also must observe part 91 regs.
Not these Part 91 regulations. 91.503 is a part of Subpart F which is specifically not applicable to aircraft operated under part 121 (or 125, 129, 135, 137)
you only consider voltage, then 10 AAA batteries would be more powerful than a car battery (15V vs. 12V) think you can start your car with 10 AAA Batteries?
Right. That's because its a size "D" dry cell. What we refer to as a "battery" is more acccurately a "cell", a voltaic cell. A "battery" is actually a series of cells, The word is used in the same sense that a collection of artillery is a "battery" A 12v car battery is actually a "battery" of 6 lead acid *cells* of slightly more than 2 v apiece.
You can't make batteries without cells. Impossible. the cell is the fundamental element a battery. A "D" size (or "C" size or "AA" size or whatever) battery is a dry cell. The idea that cells aren't made anymore is pure nonesense. Today's dry cells are usually Zinc-Manganesedioxide alkaline dry cells, or "alkaline cells" which perform better than the older Zinc Carbon dry cells, but they are still cells.
Suggest that you read 91.503. It doesn't say "D Cell" it says :".....having at least two size "D" cells....." A dry cell (correct name for flashlight "battery") that says "D size" on the side of it is probably what the regs mean by size "D" cell, ya think?
Wow, thats probably all I ever wanted to know about batteries. However, you are all only telling half of the story. Voltage in and of itself is meaningless. Power or Wattage is Voltage times Current. (W=VI) Thus 100 volts at zero amps produces no work, or in the case of a flashlight... no light. So, in the car battery example, the fact that the lead acid cells are 2 volts and the AAA cells are 1.5 volts is erelavent. If you put eight 1.5 volt AAA cells together they would make a battery that produces 12 volts, but would have very little capacity to produce high current for very long, and would therefore have no chance of turning the starter in your car.
Likewise, when considering what size flashlight to put in your flight bag, you should be aware that smaller size cells generally have less capacity than larger cells even though the voltage is the same, and therefore will produce less light, or the same light for less time.
Wow!! so what if you use Rechargeable batteries at 1.2V?
I carry a Surefire A2 Aviator with me, although our airplanes all have normal flashlights in them. My A2 uses two 3v lithium batteries. It is so bright that on cool mornings I can see steam coming off the lens! I highly recommend this flashlight.
A good friend of mine has a phenomenal website for flashlight reviews -
www.flashlightreviews.com
Darn near every flashlight you can think of is on there.
There are many non-D-cell flashlights that can exceed the output of even a Maglight 3-cell D flashlight.... A Surefire A2 Aviator (which I carry in my flight case and in my car, and is mentioned by propnose) can easily match and/or exceed a 3D Mag, or even a 4D Mag after that 4D has been running for fifteen minutes. All that and weighs perhaps 1/10 of that 4D Mag and is much, much smaller to boot.
Oh, yeah, they DO happen to cost quite a bit of money, but even a $30 Streamlight 4AA LED flashlight will totally annihiliate a Maglight in everything but range (throw). Technology has caught and surpassed the old FAR requirement, thus the change to the regs.
You forget about the...well...let's call it "copilot training" advantages of the Maglite's mass ;)
Fly safe (or else)!
David
At the airline I work for (US Airways express) we are specifically exempt from carrying a flashlight by our Flight Operations Manual. This is because they are in the aircraft.
I still carry my Mag-Light (2 D whatever) because it is one of the most efficient tools for knee-capping a guy. :D
No kiddin! Ever seen one of those monster 6-D ones? The ultimate anti-terror weapon, carrying trailer not included. Perfect for beating the stuffin out of someone...
2 D cell req. is gone...
...now the FARs only mention that the flashlight needs to provide "adequate" lighting.
skystud25 said:
2 D cell req. is gone......now the FARs only mention that the flashlight needs to provide "adequate" lighting.
Nope, still there. From the "e-CFR" current as of Jan 06, 2006:
91.503 Flying equipment and operating information.
(a) The pilot in command of an airplane shall ensure that the following flying equipment and aeronautical charts and data, in current and appropriate form, are accessible for each flight at the pilot station of the airplane:
is this different than what's required at night for the walk-around? I asked my dad this question, he'd an FAA ASI, and he sent me a copy of an FAR which used the phrase "adequate lighting" when discussing the requirements for a walk-around flashlight.
I don't know what your dad sent you. The only two places I can think of where a flashlight is mentioned in hte regulations is the part of 91.503 I quoted, and 121.549 which says "a flashlight in good working order". Maybe he sent you something which was not an actual regulation, but an excerpt from the section on airline ops manuals from his inspector's handbook?
You need the flashlight required by regulation. You can illuminate the aircraft for the walkaround using anything you want, star shells, flares, light a couple of bonfires, it's all good.
I want to do walkarounds with you, sounds like a party!
