Tug Driver said:
Perhaps its because I don't fly 121/135. The regs say that you can only fly 8 hrs but be on duty up to 14 hrs. Then you have to have 8 hrs of rest in between, right? Are the airlines more or less strict than the FAA?
Could someone please help me understand why this provokes so much controversy?
The problem is that you are like 99% of the population who thinks this isn't a bad deal. I don't mean that personally. This sounds great on paper but in practice this can be a bear.
Imagine this: You start your day at 0500. You fly 8 legs shooting 8 instrument approaches to minimums. In between, you deal with delays, gate changes, maintenance, disgruntled passengers, weather, etc. You are lucky if you have time to go to the bathroom, let alone time to eat.
Now when the day is done at 1900 your "rest" starts. During this period, you take a shuttle to the hotel (if it's on time) which can be up to 30 minutes in good weather, check in, change, go eat, go to bed because you have to be at the airport again at 0500. But wait... during this "rest" time, you also need to shower, get ready, eat breakfast (if you can), pack, take the shuttle back to the airport, etc.
So an 8-9 hour "rest" period may equal only 4-5 hours of sleep easily. And that's if the hotel isn't noisy from other people, the room temperature is adequate, and the bed is somewhat comfortable.
Also keep in mind that working a 15-hour day as a pilot requires a lot more focus and concetration than a 15-hour day in a cube hacking on a computer. I don't pretend that we have the toughest job, or that others don't work hard. But if you make a mistake as a pilot, the consequences are usually much higher than those for the average worker. Flying in bad weather takes a lot out of you no matter what plane you fly.
Now you might read this and think that I am a whiner. I am not, but I want the public to know that just because you have a 9-hour rest period, it does NOT mean you will necessarily be well rested.
The golden rule:
REST DOES NOT EQUAL SLEEP.
I often wonder if the people that make these laws had to work 15 hour day after 15 hour day with 9 hours off in between, if we would have so much trouble getting the laws changed.
So for your paper, just put down that things that sound good on the surface don't always work out that way in the end.
