RideTheWind
- Sep 16, 2003
You can tell who the freightdog is hereKeroseneSnorter said:MMMMMMMMMM......BEEEER......![]()
And I haven't hauled freight in 9 years!!!!RideTheWind said:You can tell who the freightdog is here
A Squared said:you get about 7 different answers, most of which are completely off base.
A Squared said:Never mind that the concept of an "international" foot is ludicrous when only one country on the planet uses the foot, the difference between the two units is very, very small.
Ludicrous to define something by its' definition? Ludicrous to provide the definition as defined in the country for which the question arises? Did you look up the word ludicrous before you used it?A Squared said:A nautical mile is 6076.110549 "international" feet, and 6076.103333 US survey feet.
welllllll, if you insist......Nitrogen said:I think I just saw the horse twitch his hoof!!!
Somebody start beating him again until we're absolutely sure he's dead.
Actually, each *minute* of arc is one NM approximatelyAxel said:The circumference of the Earth can be divided evenly into NM. Each second of arc on a line of longitude or on the equator = 1 NM
Check out the big brain on Hugh!......hahahaHugh Jorgan said:In 1893 the inch was defined as 100 / 3937 of a meter, or a little more than 2.54000508 cm. This is the old definition of the U.S. inch. The survey foot is 12 of these inches, or 1200 / 3937 of a meter. The length of an inch was changed to exactly 2.54 cm in 1959. It came to be known as the international inch. In 1988 the U.S. switched to all international units. The international foot is based on the international inch. The statute mile is based on the survey foot, and the international mile is based on the international foot. A nautical mile was defined as one minute of latitude. (Therefore 5400 nautical miles was equal to about 10 mega meters.) The U.S. now uses the International Nautical Mile that is defined as 1852 meters. In feet, that's 5280 ft and a NM is 6080.27 ft.
well, given that it is an approximation, it would be roughly true wheather you were considering a spherical earth or an oblate spheroid. The oblate spheroid is just an approximation also, albeit a more accurate approximation. The earth also is "pear shaped" in that the southern portion bulges slightly in comparison to the northern portion.91 said:Is that one minute at the equator assuming the earth is a perfect sphere, or the "oblate spheroid" that it really is?
Wilco.A Squared said:Hugh,
Lighten up a bit yourself.
You know what they call a 1/4 pounder with cheese in France?RogerMOSA said:Check out the big brain on Hugh!......hahaha
An appetizer?Hugh Jorgan said:You know what they call a 1/4 pounder with cheese in France?
I believe it's a minute of longitude at the equator, or a minute of latitude, as the length of a minute of longitude gets smaller toward the poles, as latitude remains constant.Axel said:The circumference of the Earth can be divided evenly into NM. Each second of arc on a line of longitude or on the equator = 1 NM
