What is a spin like??
oilcanbland
Just curious. What are they like? Quite a rush?
I am flying 152s and my instructor said that he will probably demonstrate a spin for me sometime shortly. I've done a few stalls, but no spins yet.
COOOOOOOL!
If anything...it makes you feel more comfortable in a small airplane. You get to see how much they can really take. At least that was my experience. I know they used to be part of Private Pilot training waaay back when. There's quite a debate as to whether they should be again. I did them as part of CFI training. I don't know if I would have enjoyed them as much during my Private training.
Wait 'til you're a CFI and your student does it for you....lotsa fun.
In Canada it was a requirment for the private license just a few years ago. I'll never forget the first time I had to go practice them solo, :rolleyes: freaked me right out... but as the poster above said once I recovered from it I felt alot more comfortable with the aircraft and just what it would recover from... almost by itself. :D Spiral dives however were only to be attemped with a CFI on board. Odd. :confused: Like I said this was a few years ago, not too sure if its still the same.
While Avbug and I disagree on this topic, I firmly believe that spins should be part of the private pilot syllabus. One cannot understand the rather impressive physical sensations and visual "rush" that accompanies a spin unless they have actually seen one in the air. What's a spin feel like? You're gonna be VERY IMPRESSED! IMHO, no amount of verbal instruction and simple stall recoveries adequately prepare someone for a spin.
Were spins to be included in the required FAA syllabus, would the training accident rate increase as a result? Maybe, but we could address that issue with increased CFI training. Are aircraft certified for multi-turn spins? Nope, but hey--why not simply teach spin entrys or half-turn spins? They would introduce the entry characteristics adequately. "But spins can't necessarily be limited to half a turn!" some would say. Hogwash--aviation cadets were trained for years to recover from spins after exactly one turn, two turns, or even on a specific heading. Don't tell me it can't be done safely.
Would the subsequent number of stall/spin accidents during non-instructional flying also decrease as a result of dedicated spin training? Dunno for sure, but I'd venture to say yes. The stored knowledge of how quickly a spin can develop is well worth it's weight in gold when doing such foolish things as cross-controlling during a final turn or pulling a bit too hard on the yoke during climbout. It has kept me safe thus far--knock on wood!
Let the verbal sparring begin!
First, spins are an aerobatic manuever. The only time that parachutes are not required for this particular aerobatic manuever is when a CFI is receiving spin training. I think you'd have trouble convincing the FAA that your private pilot student is working toward his CFI, and is simply thinking "long term".
They are very cool to do, and a real confidence builder. If you are not in CFI training, go to someone who teaches aerobatics, put on the 'chute and do an hour or two of unusual attitudes and spins. You will feel much more confident about your flying.
Eagleflip,
We don't disagree all that much; I believe spin recognition and training should be part of the typical private pilot curriculum. However, I believe that instructors should be competent spinners before teaching it. Most instructors have done a few token spins to check a box for their instructor certificate. Take a poll and find out how many are comfortable demonstrating cross controlled entries, and each type of spin. You'll find that most instructors are terrified of spins.
If a spin is exciting, or stresses are encountered during the spin, it's being done wrong, and taught wrong.
What does a spin feel like? Marriage, after the second year.
Well, you get the airplane just about stalling, then kick in hard rudder and yank back!
The most interesting sensation comes in the transition from straight & level to the spin. It feels like you are falling but twisting at the same time. When we did it, it slowly started to roll and quickly started to pitch down.
Once the nose is pointed towards the earth, the roll rate starts to increase rapidly. The first time you see this, it's a little scarry but it strangely feels like you are in straight & level flight. I would say the transition from S&L was more unnerving then seeing the earth spinning in front of you.
Recovery (In a 152) happens almost instantly when the rudder is used, and you will find yourself in a steep dive. Your airspeed goes nuts and you have to be careful not to pitch up to quickly. I added power on recovery too early, and got the rpm's above redline for a second (oops). The biggest sensation you will feel is the G forces. This sensation also was more uncomfortable for me then the spin itself.
After you get into a sufficient climb and your airspeed starts to decay, you add power. That's it!
The best thing about doing spins is that I was verry afraid of stalls. As soon as I did the spin, I had the confidence of knowing I could get out of a stall, and a spin if need be. I'm a lot safer because of it!
Joe
If I'm not mistaken, spins were at one time part of PPL training. More were dying in fatal spin training accidents than in real life spins, so they cut it out and went to stall recognition and avoidance. After all, no stall, no spin. Maybe an old timer around here can back me up on that, or refute it.
Spins
I agree, the nose pointing at the ground with it turning before your very eyes is unnerving. But, it is good training. Cross-control stalls are also good training. I used to give cross-control stalls to my students. Accelerated stalls, too.
Your instructor is doing the right thing by you by introducing you to spins. Some major flight schools, such as FSI, incorporate spins and unusual attitudes training in their Commercial course.
I recall from my readings that spins were part of the Private training until something like the forties or fifties. Then, the FAA pulled spin training out of the Private syllabus for the reasons mentioned and went to stall awareness training.
Oil Can
Ever see Maple tree seeds in the fall? As kids we used to call these "helicopter" seeds - there's a seed pod at one end with a feather or backbone attached. The wind would blow and all these seeds came floating (spinning) down.
Think of yourself sitting in the seed pod and you have a pretty good idea of what a spin looks like from inside and outside.
My instructor said the feeling is like a parachute jump but you keep the airplane attached to your butt. It probably is the most agressive maneuver that a "shiney side up pilot" will feel but it is most fun and definitely is a confidence booster. Enjoy the ride - stalls will get very boring after this.
I think spin training should be part of the private pilot program. I had a student put me in a spin with full power and full flaps, he promptly let go of the controls and grabbed me and screamed like a little girl. The first problem was that I wasn't watching him close enough and the second was he grabbed my arms. The third was he was 230 lbs and six foot three and wouldn't let go of my arms, so I could recover. Its a long story leading up to how he configured the airplane with full power and full flaps. The short story is half of my hair fell out shortly there after.
Goodluck
FD
spins
Just ensure that your instructor tells you before he puts you in the spin. When I was getting a CFI add on, the instructor had me demonstrate a stall in a 152. Just prior to the stall he kicked the pedals, felt like we flipped over, and all I saw was earth. Scared the crap out of me. I quickly recovered (about half of a turn) and proceded to verbally abuse him. After he got done laughing, he said that one wouldn't count as we had to go around three complete turns. The second one went much better. He did admire the quick recovery though. I can laugh about it now, but it sure wasn't funny back then.:rolleyes:
I'm glad your instructor will do spin training. As a CFI all my students did spin training as part of thier PPL. My CFI students got unintentional spins whenever it was safe even under the hood! They hated me! By the time we got back on the ground not a gyro in the ship worked......come to think of it the mechanics always new when I had a CFI student.
