what cleaner works best?
acat
Total Time
5000
For those of you that have to wash your planes what kind of cleaner do you use to get soot stains out of the paint on a turbo prop? I use a general degreaser that knocks most the grime off but end up having to use a rubbing compound to really whiten the paint. Looking for an easier way to keep the airplane bright white.
TMMT
Total Time
Alot
Gulfstream 200
Database Expert
Total Time
18,550
I suggest a Mexican, or possibly a Dominican?
AA717driver
A simpler time...
Total Time
+/-13k
Gotta go with the Dominicans. No chance for amnesty so they won't get 'uppity'. ;)
(Will this get me banned? I don't think it will. Never know what trips the "hate speech claymore" these days. 'Course, if I go down, I'm takin' G200 with me. :D)
On topic: We used to have to "wax the tracks" at a commuter long ago. Once you get the soot off, make sure you get a top notch car wax and wax the exhaust track area. It makes the job much easier next time.
TC
can99
Total Time
5000+
Try washwax dot coms degreaser... http://www.washwax.com/products.php?pid=17&detail=true
Works great, and its simple spray on and wipe off, and it gives a nice coating that makes the next time much much quicker.
this stuff does exactly as you need, brings back the paint to its original white and keeps it that way, plus if you like a sootless plane take it with you and some papertower and its a quick simple thing to wipe down after each flight.
The wash wax all is pretty impressive too, we use it in India and it gets all the crap off and brings back the paint to as new. We have no water to wash our planes with, this time is great when in a waterless environment.
acat
Total Time
5000
Will that wash wax pull the yellow out of the paint. I get the soot off just fine but it seems the paint stains underneath. The only thing I've been able to clean it with is a rubbing compound. By the way, I am in no way thrilled about having to clean our airplanes to this degree. I bite my tongue and do as I am told. If I am going to be doing it, I would like to find the best way to get it done.
can99
Total Time
5000+
on a learjet engine cowl it returns the inside the of the cowling to perfect white, and makes it looks like the engine is brand new still. it removes the yellow/brown discoloration straight out first go. the first time it was used it was hardish work, but now it has a base coast of this stuff its just a quick spray and then wipe out.
acat
Total Time
5000
thank you,
I will probably order some of that and see how it works!
CDogg
Total Time
goinup
I second the wash wax - but there's really not much you can do about the yellowing/staining (assuming it's still stained after you've cleaned off any residue on the surface), thats more along the lines of permanant paint damage from the oil sitting on it too long and seeping into the paint...best bet to even try to get that stuff out is a professional cleaning service, but even then I doubt you will get that stain out.... paint job time! :D
jdubya
Total Time
7500
Use 'Purple Power' cleaner you can get at any auto parts store. Its really harsh, you'll want to water it down some, but it will get the soot right off. Wet the plane, spray it on, then soap and water scrub brush it off. If you use it full strength it will dull the paint, but I think it still looks better than the soot.
jdubya
Total Time
7500
Also, I've washed my airplanes but I'm mostly against it.
I had to add that in there.
siouxicide
Gimme yo' change
Total Time
0-9000
Brulin Formula 815. Stuff works miracles. Spray it on and everything melts right off, from exhaust to belly grease. Little to no scrubbing needed on stuff that otherwise requires a ton of heavy cleaner and elbow grease. You use an attachment that hooks up to a garden hose. Our MX dept. has a 55 gallon drum of it.
f-5
Active member
Total Time
11000
fantastic cleaner...not 409 but fantastic....spray it on,,wipe it off with paper towels
