Welcome to the big leagues, my friend...Typhoon1244 said:Why hasn't anyone mentioned ground control at ORD? I don't know that they're the "worst," but c'mon: no readbacks, multiple clearances per transmission, punishment for those who request clarification...
I mean, it's the only place I tell my FO to "just say 'roger,' and we'll try not to hit anybody."
Does it have to be that way?![]()
You might want to give your buddies at the AFSS's a call and remind them of that. I work in Operations for a Part 121 operation, and we've tried calling them to cancel out or extend FP's and the response I typically get is - "have the crew call ATC and they'll do it." Part of the problem is that half the time the crew CAN'T call any ATC because they're either not in the plane or they're already flying on another flight that is leading up to the one I'm trying to change or they ended up flying a different flight and I'm trying to clear out a duplicate FP.Vector4fun said:I'm sure the automation guys in the Centers are scrambling to make as many discrete codes available as possible, and probably has something to do with number of times you're asked to change codes during a flight. It would surely help if you guys could be pro-active in calling us to say when you've cancelled a flight, so we can remove the flight plan, or refrain from filing multiple flight plans to the extent possible. (I've personably seen a Lear with 5 flight plans to 5 destinations in 4 different States, all in the same hour). If you're just going to be late, call us, and we'll update the P-time, rather than file a second FP. On a day with IFR WX, it's not unusual to have 10-20% of flight plans go un-used....
