Goose Egg
Big Jens
- Jul 21, 2004
Have you guys noticed that when you land with a windspeed over the demonstrated value that you start running out of rudder?
Not quite yet... That 22 knot crosswind, I had to use a lot of rudder, but I didn't have to use all of it. And that's the most I've ever been in.
But then again, I do fly also fly a Grob G109B motorglider, which is set up with a conventional gear configuration. With that long wingspan, you can't do a lot of banking close to the ground, and I can see how you could run out of rudder real quick. Crosswind technique for the Grob is touch down with the upwind wheel first, then use opposite aileron to allow the downwind wheel to touch, then use divebrakes to kill all the lift, then add aileron back into the wind. It can get a little crazy.
Oh, and I should probably mention that I like to land Cessnas with full flaps in a lot of wind. I've noticed that I like to have the extra drag--otherwise it just seems like it floats forever. This is contrary to what I've heard a lot of instructors say--that minimal or no flaps is better in a strong crosswind. I've tried it both ways; I like a lot of flaps better.
-Goose
