Vacating altitudes
As someone already said, it probably will never be an issue unless you are involved in an incident and whther or not you reported vacating an altitude is deemed to be a factor.
I can't find in 5-3-3 where it states you should not make the report if you think it will add to frequency congestion.
KSU,
You just chat yourself up a storm, block the frequencies, look for traffic with your radio and report your altitude every three feet, it it makes you feel better.
I'm very familiar with the information. You go ahead and cite the regulation that requires these reports, while you're at it. Can you find such a regulation?
I'd love to crack a book, but I'm in the MIDDLE OF THE DESERT some distance from the middle of nowhere...and can only assure you that I'll sleep better in my compound knowing you're out there somewhere reporting every little altitude change.
Safety first, courtesy second, or even a distant third. Or in your own case, blind obedience to obscurity, and be-all damned with the rest, right? Ever hear of common sense?
One should report altitude changes when one can, when the frequency isn't congested, and when it's not patently clear that you're changing altitudes.
Where's your basis in writing from an authoritative source that ATC fears and distrusts Mode C? Still looking for that one. You're wrong, of course, but it was a good effort.
KSU
While I agree with you, advisory is required any time you change assigned altitudes, this quote
Do not draw a horizontal line through an
altitude being vacated until after the aircraft has
reported or is observed (valid Mode C) leaving the
altitude.
from the ATC handbook kind of disproves your point about ATC not trusting Mode C.
While I agree with you, advisory is required any time you change assigned altitudes, this quote from the ATC handbook kind of disproves your point about ATC not trusting Mode C.
Hey dude; what's up? I don't know about any of that, but my FOM says I have to make "vacation" reports, nothing optional about it. And who am I to disobey the FOM?
This one time back at our old job, we got a PD descent on the captain's leg. I made an advisory vacating call to FLO approach (I think), and the ensuing cockpit conversation was thus:
Captain: "Is that a required report?"
Me: "No. Are you a check airman?"
OK, well, that's what I should have said. You know how some of those guys were. :rolleyes:
Shoot me a PM sometime.
KSU,
Safety first, courtesy second, or even a distant third. Or in your own case, blind obedience to obscurity, and be-all danged with the rest, right? Ever hear of common sense?
If Mode C is so reliable, why would we ever check in with our altitude? If it was reliable, than all we would need to do is call in with our call sign...right?
I've never heard a frequency so congested that I couldn't get in a 1 second radio call for vacating an altitude.
BTW...learn how to read, I posted exactly where the implied distrust of Mode C is. If you don't like it, too bad, you are just wrong....again.
You may be forgiven for and need not apologize for your inexperience.
You make wild assumptions, but see what you wish....and cannot in any way show any evidence, implied or otherwise, that the "FAA does not trust Mode C."
Especially as it is the FAA that mandates it. You're a smart one.
It does not state anywhere in the 7110.65 that aircraft must state their assigned altitude on every freq check in. The first Center sector checks the mode C. It seems all American pilots report altitude climbing, decending, level, on every check in. Only about half the foreingers do. It sounds odd when you only hear "Boston Center AZA692". I insisted they had to state their altitude, but looked it up and cannot find it.
by zbwmy
From 7110.65
5-2-18. ALTITUDE CONFIRMATION- MODE C
Request a pilot to confirm assigned altitude on initial contact unless:
NOTE-
For the purpose of this paragraph, "initial contact" means a pilot's first radio contact with each sector/position.
a. The pilot states the assigned altitude, or
b. You assign a new altitude to a climbing or a descending aircraft, or
c. The Mode C readout is valid and indicates that the aircraft is established at the assigned altitude, or
d. TERMINAL. The aircraft was transferred to you from another sector/position within your facility (intrafacility).
zbwmy, is this what you were looking for?
Request a pilot to confirm assigned altitude on initial contact unless: ...The Mode C readout is valid and indicates that the aircraft is established at the assigned altitude...
Golly gee whiz, miss martha! Does this mean that the FAA might just have a smidgen of confidence in Mode C, rather than being in mortal fear of it's deep-seeded pitfalls as KSU might have us believe? Who'da thunk it?
Stop the presses! Maybe, just maybe, the ATC system doesn't rely upon it so heavily in error after all! Is it possible?
Since when does a vacating altitude report mean verbalizing the altitude you are leaving. If I am at 10,000 and ATC asked me to descend to 8,000. Then I would say "8000 1234Foxtrot".
Uhhh, right, and at most, the controller might assume from that ambiguous transmission that you had received the clearence to descend to 8000.
Even if you had used correct phraseology, and said, "descend to 8000 1234foxtrot. the controller would still only know that you had received the clearence.
I know that you're coming late to the party and all, but jeeze, the underlying basis of this entire discussion is that the controller *may not* assume that you have vacated an altitude until you specifically say that you have vacated that altitude, or he has confirmed that you have vacated the altitude. Reading back the new altitude clearence, does absolutely nothing as far as comumincating that you are in fact vacating your current altitude.
I would encourage you to go to Avweb and read the columns by Don Brown. He explains very clearly why sloppy, incorrect and incomplete radio calls make the controllers life harder. He even addresses the question at hand and explains in detail why the vacating call *is* important to controllers and why it should *not* be skipped for brevity, and how in fact skipping it *causes* more frequency congestion.
I respectively disagree, if a controller issues a clearance that is to be complied with I would assume that a readback of the altitude cleared to and my tail number is proof that I as the pilot have received and will comply with the new clearance. Same with vectors, if I am given a vector say 270 a repeat of that vector plus my tail number to me indicates that I understand and will comply with the new vector. I would not say in my readback that I am now turning to 270.
Here's one:
Yesterday, my student and I were decending into Socal. They cleared us for a STAR about 20 miles from the first VOR. A little while later, we reach the first point of descent on the STAR, and my student starts to descend without a radio call. "Let them know you're leaving 8000," I said. He did, and they told him to stay at 8000.
Hence, we acknowledged a clearance, but that didn't mean we could descend without letting the controller know, especially where we didn't reach a point of descent until several minutes after the clearance was recieved.
Just to clarify, you must have been issued a "descend via" clearance, right?
Here's one:
To expand on Booker's question, did you get a clearance to fly those altitudes? It's hard to tell for sure from your post. If you're not clear on the matter, if you have been cleared for the XXXXX arrival, that is a clearence to fly the horizontal track of the STAR at your previously cleared altitude. In order to descend to the published altitudes, you must be cleared to "descend via the published altitudes" or words to that effect.
If your instructions were only to "fly the XXX arrival" then you were not cleared to decend out of 8,000 ft.
Doesn't matter. From a practical standpoint, it is just plain good operating practice to inform ATC "when leaving an assigned altitude".
Expect the unexpected. Plan on mistakes and changes from prviously assigned instructions. Report when changing altitudes.
It has happened a *few* times, in my experience, that when making an altitude change and reporting that change, that ATC says "Wait, maintain that altitude". So why not do it? Adds another level of safety.
BTW, that's not quite the same as repeating a newly assigned heading, IMHO.
A heading change is much more noticable than an altitude change. And the AIM says "when leaving an assigned atitude".
For a reason. More accidents have occured from misunderstanding altitude assignments than from heading change misunderstandings.
What we are, or should be, talking about is the possibility of human error, not legalese.
Of course you don't report "vacating" a heading, there is no requirement to do so. There is however a specific requirement to report vacating an altitude. You need to spend a little time in the AIM. I suspect that you don't have one, so I'll quote the parts you're confused on:
4-4-6. Pilot Responsibility upon Clearance Issuance
a. (not pertinent to the discussion)
b. ATC Clearance/Instruction Readback. Pilots of airborne aircraft should read back those parts of ATC clearances and instructions containing altitude assignments or vectors as a means of mutual verification. The readback of the "numbers" serves as a double check between pilots and controllers and reduces the kinds of communications errors that occur when a number is either "misheard" or is incorrect.
Read that carefully. This is the part of the AIM which instructs you to readback assigned altitudes and vectors. This is the readback part, it applies to altitudes and headings. This is the guidance you are following when you say, Roger, descend and maintain 8000, 1234BX
Now, skipping forward in the AIM we have:
5-3-3. Additional Reports
a. The following reports should be made to ATC or FSS facilities without a specific ATC request:
1. At all times.
(a) When vacating any previously assigned altitude or flight level for a newly assigned altitude or flight level.
Now, ask yourself, if 5-3-3(a) really just means "readback your assigned altitude" , why would they even bother to waste the ink? You are already instructed to readback your altitude in 4-4-6(b), so if 5-3-3(a) really just means "readback your altitude" it is pointless and unnecessary.
Answer, 5-3-3(a) really *does* mean report vacating the altitude, just like the words say, it does not actually mean "readback the new altitude"
Look, whether you believe that the guidance of 5-3-3(a) is mandatory, optional, advisory, merely a courtesy, or whatever ....the idea that reading back an altitude assignment statisfies the AIM guidance to report vacating an altitude is just silly, absurd even. The words are very clear and understandable, no jargon, no obscure latin phrases, just simple plain English.
Look, I would again encourage you to read the Avweb articles written by Don Brown. These articles were written with precisely you in mind, pilots who create unnecessary work for controllers because they don't understand correct communication. In one (or even several) of those articles he explains, in detail, why this report is a good idea, and it will be abundently clear why reading back an altitude assignement is not the same as reporting vacating the previously assigned altitude.
That's nice. But that wasn't my point. I wanted to clarify that time builder had been issued a "descend via" clearance for the STAR they were flying. The message implied they were descending via STAR altitudes, but like A Squared writes, being cleared for a STAR does not also clear one to descend via the STAR altitudes. That's what I addressing, not mic-keying protocol.
by zbwmy
From 7110.65
NOTE-
5-2-18 does not tell me a pilot must check in with his altitude if level. Under
c. The Mode C readout is valid and indicates that the aircraft is established at the assigned altitude. This mode c has already been validated by a previous sector.
