scubabri
Junior Mint
- Jan 8, 2003
I'm having a tough time understanding the relationship between V1, Vr and V2 and accl-stop/accl-go
The way I understand it for the aircraft I am currently in (BE90 right seat) is that:
V1=Vr this is based on the accl-stop speed based on performance charts taking into consideration weight, DA and rwy conditions
V2= the speed that you reach at 35' over the end of the runway, but I am still not understanding why/how this is important and how/why it's different than Vyse
accl-stop= the distance where you can accl up to V1/VR and still stop with enough rwy as to not crash into the GS antenna.
accl-go= this is what I am not quite clear on. Lets use 2 examples here 10,000' rwy and a 3600' rwy.
At or before V1/VR on either rwy, it's a no brainer, stop the aircraft.
After V1/VR on a 10'000, If I had an engine failure, I could still put the aircraft down, and have lots of room to spare, or if I am out of rwy, I should be at a speed that I could continue my climb at Vyse
After V1/Vr on a 3600' rwy, I have an engine failure, my only option is to continue the take-off, but I am not clear why the accl-go calculation is important, there is not much I can do about it, so I continue my climb at Vyse
So what am I missing here?
b
b
