Ih8AFYesmen
- Sep 24, 2003
Seven years ago. So what did you do?I'm a High School student in the process of applying for USAFA and/or ROTC at ERAU and I'm inquiring as to which would be considered the best approach given the goal of attending UPT and (hopefully) qualifying for a fighter assignment.
Up until about 1992 this was the case. Get into USAFA, min run the program, go to UPT if you pass the physical. However,Pretty much any AFA grad who can fog a mirror will go to UPT.
Do you know if this is still the case? USAFA gets limited slots?We had limited UPT slots in '95. USAFA got 225 for about 700 dudes and ROTC got 100 slots....nationwide.
The road taken is up to you...the destination is worth the trouble.
You can, however, make it from ROTC or OTS side. The Academy bros I know, including Magnum, are world class. I always thought they were that way IN SPITE the AFA (just kidding).
As for the Auburn language barrier...well...there were a LOT of times..especially summer quarter...when after a walk around Haley Center I was SPEECHLESS. Anyone who's been to the campus and seen so many beautiful girls in one place understands the phenonmen....
I'm a High School student in the process of applying for USAFA and/or ROTC at ERAU and I'm inquiring as to which would be considered the best approach given the goal of attending UPT and (hopefully) qualifying for a fighter assignment. The following are my thoughts (dilemmas), please comment with your perspectives and ideas.
1. USAFA receives the same number of UPT assignments as ROTC, however ROTC has a much higher number of cadets so the numbers work in favor of USAFA. However, with that, being a USAFA cadet tends to place you in a more competitive arena for those precious slots than ROTC(?). Is anyone aware of the stats asscociated with the number of candidates vs. the number of selectees in both institutions or where I could find them?
2. Conversely, if I were to attend ERAU, I would be an Aero. Science major which I feel would make me more competent (and competitive) as a pilot candidate entering into UPT. With the dual track system currently in place, I'm told it doesn't leave much time to 'catch up' like in the old days (4-5 months to track?). No disrespect, but USAFA seems to spend a great deal of time in engineering and military sciences courses at the expense of what ERAU focuses on, which is flying. Is there an advantage that I'm unaware of to attending USAFA?
My ultimate goal is, and always has been, to fly a fighter in the USAF. Although cost would be a consideration, it is secondary to this discussion (ROTC doesn't pay for flight courses).
In a nutshell, it boils down to this: one choice appears to make UPT more of a certainty, the other makes the fighter track more certain. Am I seeing this correctly? Obviously I'm willing to do whatever it takes to maximize my chances, I just need to determine what avenue to take. Before I finish, I fully understand that you're an officer first, and it would be an honor to serve as an officer in the AF...but even moreso as a fighter pilot.
Your thoughts, insights, and experience are most welcome.
Respectfully,
C2
Join a guard or reserve unit. Do NOT go active duty! You will be guaranteed a pilot slot flying an actual aircraft and not a drone. My 2 cents.
Don't know if that is completely true, the A-10 unit here in Mich was slated to go the drones after the A-10 were cut, but that has been put on hold with the A-10 rescue.Because ANG and Reserve units never change aircraft, and they especially don't convert to RPAs.
