Has anyone cleared US Customs in Shannon? If so how was it? Do they come out to the A/C? Last time I past through they where a few weeks away from offering the service.
You guys are correct. I'm an idiot. Guess I need to slow down and read more carefully. I see you were asking about U.S. customs pre-clear not clearing into the EU. Sorry for the confusion.
Here's the skinny on why pre-clearance has been delayed:
The “big news” of the last half of 2009 was the Pre-Clearance for GA out of Shannon and Dublin. It was advertised as a “full” pre-clearance and an operator could opt to pre-clear and fly into any airport within the U.S. (even non-airports of entry). The plan and the advertised release date for this procedure was squashed by CBP just a couple of months before it was to start. Nobody had apparently considered the international garbage issue. The group is working with Headquarters to find a solution to the problem and move forward with the plan. The same issues arose with the plans to provide “full” pre-clearance out of Aruba. If they modify the procedure to require operators to land at an AOE (that has de-catering available), then that would defeat the purpose of pre-clearing…so we will have to see how it all pans out.
