erichartmann
Freight Dog
- Mar 23, 2006
The rudder pedal control of the nosewheel is the only steering function affected by groundshift to the flight mode. The tiller still works until hydraulics are removed during retraction, and you can turn the nosewheel in flight with the gear down using the tiller (it's the first thing to try to raise the gear if you have trouble raising the gear). I'm with kaveman on our power application policy, and with heavyjet on being aligned with the runway when setting takeoff power at light weight and with an aft CG is a very good thing to do! (not saying the UPS crew wasn't...)
As I recall the extention of the nose strut engages the centering cam for the nose gear (which effectively disables the tiller) and puts the a/c in the "air" mode both electically and mechanically. Among other things it allows the gear to be retracted without pushing the "override" button. Turning the tiller if the gear handle cannot be moved before pressing the override button is an effort to dislodge the nose strut if it is not fully extended and allows the gear to be retracted normally.
