UAL bubbas... trivial question
aa73
Noticed anytime a UAL aircraft is parked at the gate, the wing (inspection?) light (the one that shines back on the leading edge) is always on... procedure or UALism or forgetfulness?
bored,
73
We always had to have them on for the walk around. (UAL SOP) Most guys would turn them on when they first showed up to the jet then do the walk around come back upstairs and forget that they were on for about 15 mins. We would usually remember to turn them off right about the time we're calling for a push.
That's a good idea having that on for the walkaround...
Then again my property didn't want to invest in logo lights for night running because of the weight and cost for the "option"......yet the idiots will lose billions on fuel hedges.....oh well
We forget them at Alaska too. :0
OK thanks... so you had to check that one tiny little light but not the rest of them during the walkaround?
Light bulbs + AA = same cheapness... all new tail logo lights (777, 737) deactivated for cost savings! Also, straight out of the MD80 flight manual... "Please limit the use of retractable wing landing lights... when extended, they create vibrations and waste fuel"... Unbelievable!
Or, in response to your original question, we just don't give a @#%& anymore.
bored,
73
There are lights for that? When did they put those on?
What's up big guy?
Still living the dream?
What's up big guy?
Rumor has it you wear a suit to work now? Don't start acting like the "upper crust"!!!
Just kiddin'....I returned your call a few weeks ago, no luck!
Going to Buffett tonight.....hope all is well!
Try and check your wings at night for ice....before takeoff or in the air, and that little light will mean more to you if it works.
To add to that, there is an icing MEL restriction for those lights being inop so it's a good idea to know early if they don't work which is why I think they have that in there. In a previous life, we used to test them ourselves in flight at night to make sure they work to get a jump on things for the same reason.
Agreed, it is amazing how a thread on checking your wing ICE LIGHTS is even brought up as a "needed" item and why an operator checks it at the gate.....wow.
I actually think that most on this forum don't even fly.
