flystoomuch
Member
- Feb 14, 2006
A pilot that used to work for me sent me this interpretation of 135.225:
135.225c is the reg that tells us 135 guys we have to go missed if outside the FAF and wx goes below mins.
Right ?..........
Well I guess we're all so busy tryin to understand the reg, that we don't notice that it only applies to Eligible On Demand Operators doing an approach to an airport without weather reporting.
135.225c - " ....if a pilot...UNDER PARAGRAPH B..."
135.225b - " A pilot conducting an EODO operation may begin an approch to an airport without weather reporting...."
So the only reg for normal 135 ops is 135.225a -- "....may not BEGIN an approach.......", unless you have asos and it's at mins.
SO I SAY IAF INBOUND OR RADAR VECTORS TO FINAL YOU CAN GO TAKE A LOOK EVEN IF WX GOES DOWN
So here is my answer to him:
I think it is definitely a typo and here’s why.
§ 135.225 IFR: Takeoff, approach and landing minimums.
(a) Except to the extent permitted by paragraph (b) of this section, no pilot may begin an instrument approach procedure to an airport unless—
(1) That airport has a weather reporting facility operated by the U.S. National Weather Service, a source approved by U.S. National Weather Service, or a source approved by the Administrator; and
(2) The latest weather report issued by that weather reporting facility indicates that weather conditions are at or above the authorized IFR landing minimums for that airport.
(b) A pilot conducting an eligible on-demand operation may begin an instrument approach procedure to an airport that does not have a weather reporting facility operated by the U.S. National Weather Service, a source approved by the U.S. National Weather Service, or a source approved by the Administrator if—…
(1) The alternate airport has a weather reporting facility operated by the U.S. National Weather Service, a source approved by the U.S. National Weather Service, or a source approved by the Administrator; and
(2) The latest weather report issued by the weather reporting facility includes a current local altimeter setting for the destination airport. (It doesn’t specify that it needs anything BUT a current local altimeter setting) If no local altimeter setting for the destination airport is available, the pilot may use the current altimeter setting provided by the facility designated on the approach chart for the destination airport.
(c) If a pilot has begun the final approach segment of an instrument approach to an airport under paragraph (b) of this section, and the pilot receives a later weather report indicating that conditions have worsened to below the minimum requirements…
Airports under paragraph (b) refers to airports that don’t have an approved weather reporting facility. The only requirement is a current altimeter setting. Altimeter settings have nothing to do with minimums. How would the pilot know that the weather has gone below minimums if there effectively is no weather reporting other than an altimeter setting? In other words the statement makes no legal sense.
I believe (c) SHOULD read:
(c) If a pilot has begun the final approach segment of an instrument approach to an airport under paragraph (a) of this section, and the pilot receives a later weather report indicating that conditions have worsened to below the minimum requirements…
Now THAT statement makes sense and I believe that’s how it used to read before this EODO crap started.
Looking forward to any thoughts you smart folk out there might have!
Right ?..........
