Turbo charged light twins
Mr squiggle,
you wrote:
>>>>Well, the 310 series was powered by the IO470 until the 1975 "R" version. If this quy has a Q version that has been turbocharged by way of an aftermarket turbonormalizing kit you will need to refer to the materials that supplement the Pilots' Operating Handbook for the modification.
This isn't true. Cessna made turbocharged 310's from the time they discontinued the C320 in 1967.
The T310P, T310Q, and T310R were all equipped with TSIO-520 engines. More than likely, qwerty is speaking of a T310Q, I don't know of any aftermarket turbonormalizing modifications for the normally aspirated versions. One way to tell the differnce between a 310 and a T310 is the exhaust. The normally aspirated 310 (P thru R) have 2 shrouded exhaust stacks running parallel under each nacelle. The T310's have one large diameter (about 3 1/2" dia) overboard stack pointing straight down under each nacelle, and a smaller curved wastegate stack.
Most, but not all, normally aspirated 310's had the IO-470 engines you mentioned. The 310 thru 310B had O-470's, and the 310R had IO-520's
regards
