Travelpro wheels suck! Just go find yourself some rollerblade wheels with bearings, stop at Ace Hardware on your way home and pick up a couple bolts that give you a nice fit through the bearings (use the ones that only have threading at the end and is smooth in the middle) and there you go.... Nice smooth rolling wheels! You may have to drill your old wheels out depending on your model. You may need a Dremmel to cut the excess end of the threaded part of the bolt if it sticks out too far, and possibly drill out the hole in the plastic housing where the axle goes through in order to fit the bolt you bought. I did this not too long ago after paying $50 to have Travelpro replace my wheels. The fix took only about half an hour and isn't hard at all. Make sure the rollerblade wheels you buy have a small enough diameter to fit in the wheel housing. If they are too big, they will rub the housing and won't roll. I picked up a few wheels with the bearings included at MC Sports for $1 each in the discount bin. Cheap fix, and they are the best rolling wheels i've ever seen.
