Transition Alt/Level
lumax
Total Time
1,111
For the ATC experts,
some foreign airports have different transition level and altitudes. For example, TA is 5900' and TL is 100. Are the altitudes in between unusable? Is there a time when they are assigned or can be used?
Golden Falcon
Total Time
21000+
as a general rule the difference tends to be 1500' and normally " unuseable"
Dumb Pilot
Total Time
14,000
Where there are different transition altitudes and levels, ATC may use the altitudes in between and assign lateral/horizontal separation instead of vertical separation, but as stated by GF, they usually don't use this space, normaly you will see two different transition levels depicted on the charts and its use is contingent to the current altimeter setting. Hong Kong for example has a transition altitude of 9,000FT and a transition level of FL110 for 980hpa and above and FL120 for 979hpa and bellow.
PS: far from an TAC expert mind you, just been flying under ICAO for a while
FoxHunter
Total Time
23000
All foreign airports have a different Transition Level TL, and Transition Altitude
TA. Transition Altitude is used for departure, Transition Level is used for arrival. Transition Altitude is on your Jepp chart, Transition level is assigned by ATC. Normally on the ATIS. Just listen to what the ATC controller says. On arrival if the controller says you are cleared to four thousand feet on the QNH of 1022 you should change your altimeter setting to 1022 and descend to 4000'. If the departure controller says you are cleared to Seven Zero you are cleared to FL70 and you should change your altimeter to 1013.2 and climb to FL70.The only caution is that if the QNH is below 1013.2 you should not change your altimeter until you call "flaps up". This will avoid the problem of cleaning up early and getting a noise violation.
filejw
Total Time
25000
Transition Level is not always assigned by ATC, depends on the country.
Sparse
Total Time
True, some country's publish it on the jep pages.
PGH STEEL
Total Time
9500
Not that it was questioned in this thread, but for anybody reading this and get mixed up between the two. Transition Alt. = CLIMBING The A in Alt points up. Transition Level = DECENT The V in Level points Down. Just a trick that helped me
Steel
