fastback
Registered offender
 - Feb 28, 2006
501261 said:Traffic Patterns really come down to Situational Awareness. Imagine being 10 miles south of an uncontrolled Runway 18, one guy's in the pattern just turning downwind. If you make a straight-in you'll probably safely land behind the traffic as he'll be on his next turn to crosswind turn. On the other hand if you enter on the 45, you'll most likely both be on the downwind, at the same time in place.
Which is safer or better?
Great situational awareness there. If you're 10 south of the field setting up for a straight in, that puts you on a tailwind landing on 36 as he's touching down on 18. That's okay, I've seen plenty of Lear and Citation yahoos completely screw the pooch in the pattern.
No, you don't have to do the 45 thing, just don't make right turns in a standard pattern. Join upwind, land straight in, off the base, whatever. Just have the sense [it's clearly not common] to figure out where you are and where you are going before you hot dog it in there.
