John Hewlett
Member
- Jul 14, 2002
- Total Time
- 270+
ILS approaches are timed approaches. Timing should be done as you cross the FAF inbound on the approach. However if all is well on the approach timing shouldn’t play a big factor. An ILS approach can be completed with a dysfunctional glide slope. LOC minimums are published for the approaches in the event of glide slope failure.
I fly in and out of Cape Girardeau Regional Airport (KCGI) on occasion. There for I will use that airports ILS runway 10 approach as an example. This is my normal procedure to flying the ILS 10 approach. I fly in from the southeast almost every time. The IAF is the Dutch NDB/LOM. There is a one minute hold for this approach, standard hold over the NDB. This hold is not required. I fly a parallel entry to a hold that I am not going to do. Fly back to the NDB, which also for all practical purposes serves as the FAF. I cross the NDB, the glide slope is active. I start my time. Now it should take me 3:56 to get to the MAP which is the MM. I fly a category B aircraft thus the approach should be flown at 90 KIAS. As you probably know the components of an ILS include, localizer, Glide slope, lighting, and marker beacons. Fortunately for us as pilots all of these things make ILS approaches extremely precise. That’s the norm.
Now let’s throw a problem in there. Your glide slope just became active and your time has started. The time is now 1:00 on the clock. You are doing your scan. When your vision comes back to the glide slope it is centered and there is a GS Inactive flag there. You have no glide slope. However your time as been started. Look at your approach plate, under the profile view. You will read (on this approach) S LOC-10. Your MDA (formally your DH) is now 860 feet instead of 538. However now you have an advantage. Your time has been started and you that you have 2:56 seconds at 90 KIAS left before you should be at your MDA. With out the time started, all you could do would be to come down to MDA and take a peak. Starting your time can mean the difference between landing and going to your alternate. If you get down early on the LOC you can always fly to the 3:56 and see if you see the runway environment.
As far as the LOC goes, if there is a full scale deflection. You should declare a missed approach. Time really isn’t an issue there. Always keep in mind that as the PIC you can declare missed anytime you want if you feel something fishy going on. On one more note and this really isn’t something that makes a whole lot of difference but most Airspeed Indicators read in MPH. If you want 90 KIAS look at the inner ring on the airspeed indicator.
Hope this helps!
John
Hope this helps!
John
