Thunderstorm movement
Have spent quite a few hours flying right next to "the beast" in smooth air, again, depending on the position of the gust front.
Having spent quite a few hours flying right next to the "beast" in extremely rough, turbulent air...first of all, there is no "gust front," but a shear axis, and the debris field will be on the lee side of that; the downwind side.
If you were working above the base on weather mod, you were working the rising columns on the upshear, or upwind side, and there's certaily turbulence to be found there. Seeding the debris field is of no value.
In any event, there certainly exists hazard close to the thunderstorm, and certainly beneath the anvil, for some distance downwind.
This is from an aviation weather book produced by NOAA and FAA.
It shows movement in the direction of the anvil.
Well, we, as well as our meteorologist, called them gust fronts...sounds like a similar concept. I was working at the base, and although we had a Cheyenne that worked higher, I never got involved with that.
Yes, there's hazard close to the thunderstorm. Yes, I'm going to stay far away at my current job. But many of the notions people (and textbooks) have about thunderstorms are overblown, even though they may be true in a select few cases.
Not quite sure what you mean by this statement, there are many pictures available of aircraft that were badly damaged, or worse from big wx systems, just recently in my area, the front of a Asiana A321 was destroyed. Not very healthy to under estimate this stuff, the books are an aid to understand the basics, those of us operating out there understand each system is different, there is no single way to look at each, remember the Chief Pilot at AA going into LIT, having nice shiny equipment is one thing, using your head is something else, flying over the top at 430 is not everyones option, what happens if you have to descend for some reason?
Having worked storms up close and personal from the base to the top with an airplane packed with scientists and ground support with some very sophisticated instrumentation on board and on the ground watching me...I can tell you it's every bit as bad as both the textbooks and real-life experiences say it is. If you never experienced it, don't mistake that lack of experience for reality.
A gust front occurs on the surface, and is the outer edge of outflow that accompanies a downdraft or microburst. It is the result of a descending column of air spreading out laterally as it's path is altered by terrain.
Aloft, there is no "gust front." You have wind direction, which as any student pilot knows, varies in intensity and direction at each level in the atmosphere. Wind blows from upwind to downwind, upshear to downshear. A debris field may exist downwind of the cell at any level, and several may exist moving in different directions. Further, while the "overhang" or "anvil" at the top of the storm marks blowoff at the thermal upper limit of the convective cell, it does not indicate the direction of movement of the cell. Only the wind direction at that altitude.
http://i94.photobucket.com/albums/l8...g?t=1176574474
Yes, and no. There isn't a correlation between the two, though both are shown in the diagram. Further, the diagram shows air circulation vertically, but doesn't define horizontal flow through the cell, and is an oversimplification, and doesn't take into account variations in wind direction at various levels in the cell, or the continuous decay and fresh development that actually characterizes a convective cell.
The diagram isn't intended to suggest that a cell moves in the same direction as the anvil.
I'm not using my experiences as an excuse to violate regs, be unsafe, or to fly into something I shouldn't, even if I am pretty sure I would come out OK. Please, guys, I know the history behind all the crashes. ALL I AM DOING IS PASSING ALONG WHAT I LEARNED ABOUT STORMS FROM WEATHER MOD...not recommending that one should apply this knowledge to their current job, just general, "fun to know" thunderstorm knowledge. But perhaps I'll just keep my mouth shut next time.
With a few exceptions, (in the continental US) all frontal systems and thunderstorms move in a westerly direction. Winds aloft at altitudes where the anvil forms almost always run in a westerly direction. The sheer Avbug talks about is at the tropopause. That is where lapse rate, winds and pressure all change very dramatically.
So, as a thunderstorm builds to heights near the tropopause, the moisture that is carried up gets blown out to the west, forming the anvil. That is also the general direction of the movement of the storm. What to watch out for is the continuing build up beyond the anvil. That storm will have tremendous power and is likely to produce some hail and tornadic activity.
Westerly? I guess KSU has a good meteorology program.;)
2 more cents from an ex weather mod guy. It's probably been posted, but the anvil indicates what the direction the upper winds are blowing from. The steering winds for the storm are typically in the 700-500mB (15000'-18000') range...unless you start getting into the MCC (mesoscale convective complex) type storms.
There's also a difference between anvil and blowoff clouds. Anvils are still associated directly with the thunderstorm and can get nasty. Blowoff clouds can extend many miles downstream of a thunderstorm and are pretty tame. Also, those Mammatus clouds that look like big bubbles hanging down from a cell are NOT indicators of extreme turbulence. They are just slowy descending ice crystals.
AvBug, are still doing wx research?
