sky37d said:
Thanks to all
I never thought about lower being better. Obviously, higher than anything is great, but a normally aspirated airplane is only going to go so high.
I do know how to use the tilt feature, and the only time I have seen really heavy stuff, we deviated around it. So was everyone else that day.
The advise to stay on the ground is sound, but not always possible. Comfort factor is a big thing, and I have lots of things yet to do, so no hari kari on this trip. I normally disconnect the A/P as soon as it gets choppy, for the reasons mentioned, but also most will disconnect on their own at some point, and I don't want that to happen when it decides, rather when I decide.
What else? Great info here as always.
Sky37d,
It was wise of you to ask for advice. You got some that is very good and some that is very bad. As always, the problem is knowing the difference. Hopefully, I can join with those who gave the good advice.
Before we get into the "flying" aspect consider this: A doctor buries his mistakes. A pilot is buried with his mistakes.
1. Regardless of your knowledge of how to use your radar or the quality of your equipment, remember always -
radar is NOT a penetration aid, it is an avoidance tool.
2. Do not, under any circumstance, intentionally penetrate a thunderstorm. [You are not a research pilot or a hurricane hunter]
3. Do not, attempt to use your radar to penetrate a squall line. That means that you must have a clear path, that you are
certain will remain clear and permit you to pass with at least 20 miles from any cell on both sides of your track. Has it been done successfuly? Yes, it has. It has also been done unsucessfully.
4. The concept of the "lower" altitude being best is based on your ability to remain visual and circumnavigate cells while in VMC.
It does NOT mean that you can fly safely through or under any storm. This "technique" has produced safe passage. It has also produced disaster (Braniff)
5. As enigma correctly pointed out, do NOT fly over the "top" of a cell even though you are "in the clear". Fly
around it.
6. Avoid flying under anvil heads (in the clear) especially at higher altitudes. Hail is not kind to the airframe.
7. Your radar can "see" cells, but it cannot reliably see
through cells. Don't get "suckerd" into believing that it can. [Southern][ValueJet]
8. Never ever be too proud to land at a suitable airport and wait it out or to deviate to your alternate when necessary.
9. No schedule, whether private or commercial, is ever important enough to cause you to take chances or ignore safety. [Some calculated risk is always necessary if we fly. On the other hand "chances" are the roll of the dice. Gambling and flying are incompatible].
10. "Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect." — Captain A. G. Lamplugh
With respect to your autopilot - IF your equipment has that capability consider this > when you anticipate moderate turbulence, disengage the altitude hold but leave the wing leveling and heading functions engaged. Not all autopilots can do that, but it does work if the unit can and it's easier than hand flying.
Finally, keep in mind that "manuevering speed" is not always the same as "turbulence penetration speed". Consult your AFM (POH) for the correct numbers.
Enjoy your trip, it sounds like fun. Just remember that good judgement is always superior to flying skill.
