apcooper
Dude, where's my country?
- Sep 4, 2004
Today I rode along with a 65 hr private pilot in a 152 for a video project and surprisingly as he is going through the checklist he doesn't notice the flaps fully down even though the lever was set at zero. When I'm flying I obviously go through the checklist and visually verify they are up or at 10 deg. This time It didn't occur to me to check since he was PIC. So we TO and about 5kts past rotation speed the plane seems a bit nose heavy and wanted to yaw and roll slightly to the left but not in such a drastic way that I hadn't seen before (like on my 1st TO ever when I didn't understand "right rudder") so at about 500 AGL turning crosswind I notice a lot of nose down trim needed as well as a slower climb speed. Sure enough I look out and see the flaps stuck down and moving the lever does nothing!! I quickly ruled out electrical failure and we decide to retuern to land. Surprisingly they were asymetrically stuck as well but corrected with very little aileron/rudder. My friend seemed concerned about getting low and slow on final so he ends up being well above the VASI at about 85 kts. I told him to just fly a normal approach and after an uneventful landing I visually inspect the flaps and surprisingly I could not even tell they were asymetrically deployed. I guess aerodynamically it takes very little to induce yaw!!
Lesson learned, I should not have been as complaciant as I was by sitting back while he ran the checklist. This would not have happened if I'd been running the checklist. I ALWAYS visually check flap settings. I was very surprised that a underpowered 152 could climb that well w/full flaps!!
Your thoughts and opinions are welcome.
