T-6 and T-37 eagerly awaiting UPT
its not that i wouldnt fly it...i guess ive been to influenced by stories of the t-6 from people at upt...
Sorry -- didn't mean to sound so accusatory. Trying (badly) to be sarcastic. I've heard the T-6 is an awesome machine.
It's just that the T-37 is such an icon -- a wonderful airplane that served me well both in UPT and in ACE. I've got a lot of great memories in the Tweet.
I'm sure I learned more about flying in the T-37 than anywhere else.
If you have a choice, take the tweet! It'll put hair on your chest. You'll be flying a "real" airplane at your Guard unit for the next hundred years or so. You might as well learn on technology for the same era. NKAWTG!
Hi!
Oh yes, you definitely want to fly the Cessna T-37, the best trainer ever built!
It's a classic. A classic is something that used to be good or popular, but has now been bypassed by current technology.
So, the T-37 may have a few quirks of a typical classic, for example:
The air conditioning doesn't work on the ground. It doesn't work in the air, either.
It is slightly noisier than the T-6. For example, you wear a pair of foam plugs under your noise-attenuating helmet, and you still have hearing loss after UPT.
When you push the throttles up to takeoff, nothing happens, except your ears recoil in pain, and it's hard to hear the tower telling you that they only cleared you for an IMMEDIATE takeoff, and asking you why you're still on the ground. Then, after about 10 seconds, you check to make sure the throttles are at their stops, because, still, nothing seems to be happening. Then, you look over on the parallel runway and watch the C-172 accelerate away from you down the runway, rocket into the sky, and dissapear into the wild blue yonder.
In return for the massive lack of thrust from both of the T-37's mighty engines, you still get crappy range/duration.
There is no pressurization, so those cross-country flights at FL 250 (it takes about 1.5 to make it that high) are a real pain in the a$$, not to mention about everywhere else.
The T-37 is an excellent beginner instrument platform. That is because the gauges and instruments have been randomly scattered around the aircraft. Since there's no good way to scan the instruments, you can do it however you want and the instructor can't tell you you're wrong. (A civilian guy I was flying with, in a real jet, went with me and looked inside a T-37 cockpit. He said, "Oh my g0d!!!"
The "ejection seat" is supposed to work correctly, as long as you're withing parameters: At least 10,000' AGL, with a positive vector away from the ground, you're flying fairly wings level, and you're going at least 450 kts. (An instructor and student I know ejected out of a burning T-37 in the pattern. Just after takeoff, it caught fire. The IP instructed the student to eject first, and then the IP ejected. I told him it was very noble that he looked after his student and put his safety first. The IP told me he thought they were too slow and too close to the ground when the student got out, and he wanted better parameters!)
But, best of all, is the sexy, sleek lines of the T-37! It just screams to all the ladies, "Date me, because I'm a JET PILOT!"
So, you definitely want the T-37, it's head and shoulders above the T-6
Cliff
YIP
PS-I hope you get the T-6! The main thing to do is take your time with the engine controls. Positively identify which control you have in your hand. You don't want to shut the engine down by mistake, especially close to the ground unless you want to test the excellent ejection seats.
Super Tweet
When you push the throttles up to takeoff, nothing happens...
Too bad the AF didn't upgrade all Tweets to A-37s!
--on takeoff, you had to pull the nose right up or you would overspeed the gear before it could retract.
--it would do a triple immelmann
--max range procedure was to climb to 25,000 ft. and shut down an engine
well ill see what i get. i wont complain about either but the t-6 sounds fun. im not even there yet so i probably couldnt make any judgements about either until flying both. but i wont ever fly both most likely...one thing i like about the kc-135 is that it still is kinda old school. its not all glassed out. i guess im kinda contradicting myself since i want to fly the glassed out t-6. i think i just figured out for myself that either the t-37 or t-6 would be just fine with me...just get me in the cockpit at this point.
good point good point
atpcliff said:
Hi!
Cliff
YIP
im kinda used to no a/c already....i love sitting on the ground with engines running in texas or phoenix or turkey and having the cargo door closed....ahh sweet
Otto77 said:
if you want air conditioning that works...come join us at t6 land
we will see....we will see...i should have school dates soon...hopefully by the end of the month...it would be a good way to celebrate the 4th of july
A future stud worrying about what primary trainer he'll fly??? Good god man! Just go start flying jets...who cares what the primary trainer is! At least you're flying airplanes in the good ole' USAF - that's what matters!
Go Tweet. Join the generations of aviators who trained in the Dog Whistle. It's good to train in challenging aircraft. You'll be a better pilot for it.
