FastCargo
Is that the tanker?
- Dec 12, 2001
Couple of things from the T-38 loss:
A bird did go through the top part of the front seaters canopy. The front seater lowered his seat all the way down.
It was found that this causes problems the lower the seat is. The rocket in the seat is inside a flex tube. The tube bends into a sort of L shape as the seat is lowered (with the rocket at the upper part of the tube). The idea is that as the seat moves up the rails to exit the aircraft, the tube restraightens to let the exhaust point straight down (as I understand it). That didn't happen, and instead the rocket burned through the tube, causing the exhaust to split (some out the hole, some down the bent tube) and the seat to spiral out. The front seater got lucky that he still got a good man-seat separation. The T-38C fleet is now being retrofitted to fix the issue.
What SATCFI said is correct, the IP's chute was basically a streamer because of the heat of the fireball. He's lucky to be alive at all...I hope he can get back to flying someday.
Gallows humor...this is not the way to reinforce your callsign...
FastCargo
FastCargo
