Sunglass polarization and a/c windows
Well, that was quick....But, I believe that this will establish maximum coolness:
http://www.speakeasydistribution.com/store/saucy-goods/blow-up-sheep-saucy-goods-/prod_3804.html
Someone said you should warm it up in the tub for a few minutes, and THEN put your Oakley's on.....(?)
I'm just sayin' what I heard...From another guy. Who flys Jets. Not that there's anything wrong with that...
YKW
I never knew such a thing even existed. wow. thats a twisted mind!
The FAA viewpoint - FWIW
http://www.faa.gov/pilots/safety/pilotsafetybrochures/media/sunglasses.pdf
POLARIZATION. Polarized lenses are not recommended
for use in the aviation environment. While useful for blocking
reflected light from horizontal surfaces such as water or
snow, polarization can reduce or eliminate the visibility of
instruments that incorporate anti-glare filters. Polarized lenses
may also interfere with visibility through an aircraft windscreen
by enhancing striations in laminated materials and mask the
sparkle of light that reflects off shiny surfaces such as another
aircraft’s wing or windscreen, which can reduce the time a pilot
has to react in a “see-and-avoid” traffic situation.
