Student Endoresement: High Perf / Complex
User546
The Ultimate Show Stopper
I have a student who has received about 10 hours dual so far, with all the training in a Cessna 172.
He went out last week and bought a Piper Dakota as a personal aircraft. For you that aren't familiar with the Dakota's, it has a 235 HP engine, fixed-gear, with constant speed prop.
So now I will be doing all the rest of his primary training in this Dakota.
My question is, when do I need to give him his complex and high performance endoresement to fly this airplane? Should I do it as soon as possible (as soon as proper ground and flight criteria is met) or is it not important for him to have until he's ready to act as PIC in the aircraft (first solo, etc.)?
Never ran into a situation like this before, and I want to make sure I do it right.
Thanks.
10hrs of dual with you? or just 10hrs dual total, as in he's not even a private pilot yet?
If he's already a private pilot, he needs to log PIC while flying the plane, and can't until you endorse him.
Either way -- your signature on that endorsement says, "Dear FAA, I certify that if this guy kills himself in this plane, that you will hunt down my ass and harass me for the rest of my life."
Don't sign it until you feel that he's ready to fly it as PIC. I can't even begin to imagine how much trouble I would have gotten myself into flying a 235HP airplane with only 10hrs under my belt. :)
Whatever you do, don't risk your ticket.
Thanks.
He would only need high performance though correct? Since it doesn't have retractable landing gear?
I would assume being HP it has Cowl Flaps? But it's still missing the gear, so does it qualify as complex?
-mini
-mini
Nope - to be complex it needs "all of the above". So it's only HP.
Many pilots earn their private in high performance and/or complex airplanes. 235HP means nothing. Pilots kill themselves in everything from an ultralight and up. Quality of instruction and maturity and judgement of the student/pilot determine the risks they present themselves.
If you feel confident your student understands the aircraft and demonstrates the skills required to safely fly the aircraft, then endorse his logbook and student pilot certificate (medical) before he solos.
Giving an endorsement for HP, complex, tailwheel or anything else doesn't bring the FAA on you any faster than a student you signoff on a 172, or a bfr.
Document your training and cover the items on the PTS. You are not forever responsible for someone's carelessness or lack of judgement.
minitour said:
woohoo...that means I passed ground school :rolleyes: yay!
-mini
That's always a good thing to realize :D
Training in a HP plane is very doable, chances are it'll take longer before he's really ready for solo or his checkride.
Vic said: "Either way -- your signature on that endorsement says, "Dear FAA, I certify that if this guy kills himself in this plane, that you will hunt down my ass and harass me for the rest of my life."
We'll only Hunt You Vic, Only You....
--Cowl Flaps doesnt mean HP-- it means the aircraft has Cowl Flaps--
--Find the correct endorcement in your AC 61-65D, as a CFI you should have a copy, in not there are many sites you can sown load it..
JAFI
JAFI
This I know, but I would assume a bigger, more powerful engine would almost "require" them to keep the temperature from going to extremes...
like I said..."I would assume being HP it has Cowl Flaps?"but that was just a guess
-mini
you don't have to give a primary student an endorsement to solo a high performance airplane because the make & model is covered in the required solo endorsements. you will have to give him the high performance endorsement AFTER he takes the private checkride.
I agree that 235 HP airplane is a lot of airplane for a 10 hour student, and I was a little suprised when he called to tell me he bought it. But on the flip side also, since he's so low time, it might be easier for him to transition and "learn" the airplane, rather then having 30 or 40 hours in a C172, and then having to deal with how to manage all this extra horsepower and prop lever. In other words, learning to fly this airplane this early on in his training (when frankly he's still green anyways) he won't know much difference between it and a typical trainer.
Agreed it will take him a bit more time to probably solo, but he's not getting the sign-off until he's 110% ready anyways, with or without a HP airplane.
And I thought with the airplane having a variable pitch prop that it made it complex?? I could look it up right now, but I'm away on a trip and can't reference any of my books.
User997 said:
...But on the flip side also, since he's so low time, it might be easier for him to transition and "learn" the airplane, rather then having 30 or 40 hours in a C172, and then having to deal with how to manage all this extra horsepower and prop lever....
I kind of agree...
looking back, I would have just taken out a loan and done my private in a Bonanza...gotten used to the power and the prop, gear, etc, etc...
Would it have taken longer? Yeah, probably, but when I get to move into bigger stuff, I might not have to work as hard to get ahead and stay ahead of the plane...but the 152s can be fun too...
I guess the other side of that is there's always something bigger/faster to transition into so it doesn't really matter...
-mini
FAR 61.31
e) Additional training required for operating complex airplanes.
(1) Except as provided in paragraph (e)(2) of this section, no person
may act as pilot in command of a complex airplane (an airplane that has
a retractable landing gear, flaps, and a controllable pitch propeller;
or, in the case of a seaplane, flaps and a controllable pitch
propeller), unless the person has--
Danka FlyGuy... and for everyone else for answering my questions!
That's why I love this board so much! Well, that and all the hot chick's you guys have in your avatars... :D
User997 said:
I
here 'tis: 61.31
e) Additional training required for operating complex airplanes. (1) Except as provided in paragraph (e)(2) of this section, no person may act as pilot in command of a complex airplane (an airplane that has a retractable landing gear, flaps, and a controllable pitch propeller ....
If ya have the net, you can look it up:
http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?&c=ecfr&tpl=/ecfrbrowse/Title14/14tab_02.tpl
We train PP students in HP aircraft all the time - the 210 HP T-41s. Now granted, we are at 6,000 MSL, so that cuts down the bite quite a bit, but it seems having some extra power (within limits) is more of a help than a hinderance in basic training.
Cheers!
You should talk... so uhh, ya go her number?
Try training primary students (i.e. totally green) in 300 HP bonanzas. It's actually not that bad once they get used to it. A little nerve racking for me though on first solo, got the binoc's in the tower to make sure their gear is down each time...
~wheelsup
This ain't nothing new partner, many have gotten a private in airplanes bigger, faster, and more complex than this one.
Mesa's PDP has been using A-36's with the I0-550 300 HP since day 1 with 0 time pilots in the left seat.
No big deal at all..
3 5 0
350DRIVER said:
...Mesa's PDP has been using A-36's with the I0-550 300 HP since day 1 with 0 time pilots in the left seat.
3 5 0
I always wonder what goes through their mind when/if they hop into a 152...
mini, the funny thing is most of the guys never get into a GA aircraft after leaving the program unless they flunk out of training or don't pass the interview.
It's nuts to think that once they get their commercial they'll never see another SEL aircraft unless they want to!
~wheelsup
~wheelsup
I feel so bad for them...never having the "experience" of cramming into a 152 and religiously doing a W&B ten times, even though the numbers are always the same because you feel that maybe this tenth time it will tell you that you can actually have fuel on your flight today...but no, it's still the same...
I think flying a 152 or Citabria (or something similar) should be prerequisite for flying a transport category plane...but thats just me...
-mini
This is what I'd do; fly with him in the Dakota a few times. If it looks like he'd be able to handle it, I'd continue training with him in the Dakota. If it looks like it is too much airplane for him right then, I'd suggest to him that he park the Dakota until he has his private certificate. There's a pretty big difference between 10 hours and 50+ as far as flying skill goes. If he insisted that he fly the Dakota, I'd then explain to him that solo proficiency in the Dakota is going to require a bit more flight time, but I'd have no problem working with him during that time--just so it was known that it might take a while to solo.
-Goose
Problem is that our local airport is uncontrolled and there is no longer a airplane for rent anywhere on the field (thus why he went and bought his own airplane).
So there's really no alternate to him flying this airplane in that given scenario.
I'm fairly confident though that this student is a cut-above most. He's very passionate about flying, wants to do it 4 and 5 times a week, and when I show him something he picks it up the first couple tries, and never forgets. In addition, he's very book-smart when it comes to studying and understanding things. I think if anyone, he'd be more then capable of handling and flying this airplane.
I really wouldn't worry about it.
Shaun mentioned the T-41. I know folks who are teaching in the civilian equivalent CE-R172 (Hawk XP) series with both the stock 195 and the un-derated 210 HP. I have a friend who, halfway through his training decided that he was going to buy a 182 and finish his training in that. Heck, I even know a guy who learned to fly in a CE-210! The original Katana had a constant speed prop and was still used as a primary trainer.
A Dakota isn't =that= complicated. Might require a little extra time since there are additional dials and levers, but the student will simply see that as normal within a very few sessions. I'm convinced that learning a complex or HP aircraft after the PPL is more about un-learning things you can get away with in the simpler airplane than about the high complexity of the new systems.
To qualify for 'Complex' the A/c must have a adjustable prop....retractable gear and flaps....the airplane needs all of those to be complex..
So you'll never get be able to get complex endorsement in any Piper "training" aircraft!
That must be why I got my complex in a Cessna 182RG!
Huh? I must've missed somehting.
